Meaning of a Subspace
81
Main Question or Discussion Point
Hi PF!
I want to make sure I understand the notion of a subspace. Our professor gave an example of one: the set of degree n polynomials is a subspace of continuous functions. This is because a) a polynomial is intrinsically a subset of continuous functions and b) summing any polynomials yields another polynomial (closed under addition) and c) any polynomial multiplied by a constant is still a polynomial (closed under scalar multiplication).
If my reasoning is correct, then I think the set of discontinuous functions is NOT a subset of all real functions. To see why, consider ##f(x) = 1## everywhere except non-existent at ##x=1##. Then take the function ##g(x)=1## when ##x=1## and non-existent everywhere else. Then the sum is clearly continuous. (How would this change though if I changed non-existent to zero? I know the result is the same, but is ##g(x)## as I have defined it even discontinuous--I realize this is a real analysis question.)
Answers and Replies
PeroK
Insights Author
4,410
Hi PF!
You can't choose functions that are not defined at some point, as functions that have different domains can't be added so they don't form a vector space. The space of all real-valued functions would imply that they all all defined on some fixed domain.
Also, functions that are not defined at a point are not necessarily discontinuous. They may be continuous on their domain. A good example is the function ##1/x##, which is a continuous function on its domain.
Instead, you need to think of two genuinely discontinuous functions that can be added to form a contiuous function.
Or, perhaps you could think of a simpler example using a subset of the polynomials that does not form a subspace?
S.G. Janssens
Education Advisor
862
624
I would say: "The set of polynomials of degree at most ##n##". (Here you regard the zero polynomial as having degree ##-\infty## or you should stipulate that this set includes the zero polynomial.)
You mean to say "subspace" instead of "subset"? In addition, I very much second the remarks made by PeroK. They appeared on my screen while I was writing this.
Or take a discontinuous function and multiply it by zero.
81
Thank you both for finessing my logic! I really appreciate both of your input!:biggrin:
Related Threads for: Meaning of a Subspace
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
