Measuring Gravity with a Zero Mass Device?
In summary: There is some evidence that the gravity of large objects does indeed seem to affect the speed of light. This has been measured using the Doppler shift of light waves.In summary, light is massless and is affected by gravity. However, it is possible to make an instrument that detects gravity without relying on its mass.
YADA
If I had a hypothetical gravity measuring device that had no mass, would it be able to measure the gravity of a planet, that does have mass, as it approached it? Or would it not detect any gravity because the device has no mass?
I hope this makes sense...
It would have to have some form of mass to be affected by gravity. Therefore it would have no way of measuring the gravitational pull if it is unaffected by it. Unless of course it was measuring another object which did have mass being pulled towards the planet.
Thanks for the reply, Uk_Ghost.
So the Earth, or any other planet, doesn't actually have gravity? I mean, is gravity just the attraction of two objects with mass? If an object was somehow isolated and couldn't interact with other objects, then it wouldn't really have gravity?
Yes, all objects with mass have gravitational pull. The amount depends on the mass of the object. Like how the Earth has enough mass to be able to keep the Moon in orbit around it but the Moon's mass is also big enough to affect the Earth's tides. If an object was able to have no mass it would not be attracted to anything with mass.
I'm not sure what you mean by isolating something though. I'm assuming its the same concept as 'if a tree fell in the woods and no one was around to hear it would it make a sound?'
Yes, but I didn't think of it like that. So it's no really a question worth answering...
Thanks again for your help.
No worries :)
The previous response is incorrect. It was one of the early successful tests of general relativity that massless particles like photons are also measurably affected by gravity.
interesting; does that mean photons gravitationally attract other photons? or is the gravitational attraction with photons a special case and only 'one way'?
As has been mentioned, light is massless and yet is affected by gravity. Therefore it is possible to make an instrument that detects gravity without it itself having any mass...or at least without it relying on its mass to make the measurement. It could be an intrument that relies on light, or time, or speed instead.
In fact, we can calculate the gravity of certain cosmic objects simply by looking at how they bend light. So in effect we are measuring ther gravity without directly using any mass to do so.
Lsos said:
As has been mentioned, light is massless and yet is not affected by gravity. Therefore it is possible to make an instrument that detects gravity without is itself having any mass...or at least without it relying on its mass to make the measurement. It could be an intrument that relies on light, or time, or speed instead.
first paragraph, surely a typo on first line?
second paragraph, I am fairly sure the OP is talking about the measuring device being affected by gravity and being massless, as opposed to being massless and capable of measurement (based on the wording about approaching the object)
Well, that is hard to answer without a complete theory of quantum gravity, but if you change from "photon" to "brief pulse of light" then yes, they do interact. Each would be described by the Aichelburg–Sexl ultraboost solution.
what a great name for a theory :smile:
The speed of light is a constant. How could you possibly it to tell us the gravitational pull of a planet?
The only time light is 'bent' is during gravitational lensing from something huge like a black hole or a galaxy cluster which creates warped space-time which would bend everything in it. It that scenario you would be able to tell the gravitational effect of warped-space on light but you wouldn't be able to use light to tell us the gravatational pull of a planet, which was the original question.
Gravity bends light. The more gravity the more it bends...
This means that whether it goes around a cluster of galaxies or a cluster of fat chicks, it should bend. Yeah, good luck measuring this...but nevertheless the effect is there.
Speed isn't the only property that light has that can be used to tell us about the gravity of a planet. Gravitational lensing has already been mentioned, and there is also Shapiro delay and gravitational redshift all of which can be observed within the solar system. The frequency change due to Earth's gravity could be detected using technology from 1959: http://en.wikipedia.org/wiki/Pound–Rebka_experiment
1. How does a zero mass device measure gravity?
A zero mass device measures gravity by using a pendulum system that is unaffected by the weight of the device itself. This allows for more accurate measurements of gravity without any external forces affecting the results.
2. Is it possible to measure gravity accurately with a zero mass device?
Yes, it is possible to measure gravity accurately with a zero mass device. By eliminating the weight of the measuring device, the results are not affected by any external forces and can provide precise measurements of gravity.
3. What are the advantages of using a zero mass device for measuring gravity?
The main advantage of using a zero mass device for measuring gravity is its ability to eliminate the weight of the measuring device itself. This allows for more accurate and precise measurements of gravity without any external factors influencing the results.
4. Are there any limitations to using a zero mass device for measuring gravity?
One limitation of using a zero mass device for measuring gravity is that it may not be suitable for all environments. For example, it may not work well in extreme temperatures or in areas with high levels of electromagnetic interference.
5. How can measuring gravity with a zero mass device benefit scientific research?
Measuring gravity with a zero mass device can benefit scientific research by providing more accurate and precise measurements. This can help in studying the effects of gravity on various objects and phenomena, as well as in understanding the fundamental laws of physics.
  • Other Physics Topics
