Homework Help: Measuring angular momentum
  1. May 24, 2012 #1
    I have a wavefunction ψ(r), I want to know what the probability of obtaining a specific value, say 0, Is upon measuring the z-component of the angular momentum Lz
    What do i do?
    3. The attempt at a solution
    My first thought is to apply the Lz-operator to my function and see if this yields the value im looking for, and if it does not the probability is simply zero. However when i actually do the calculations i don't even get my original function back, and i'm not sure how to interpret this result. i.e. I expected that i would get somethibg like Lzψ(r)=lψ(r) where l is the eigenvalue of Lz. But maybe this is a faulty reasoning?
    Edit: Maybe what i'm wondering is really what happens if you try to measure a variable of wich my statevector is not an eigenfunction (as seems to be the case) or would such an action actually colapse the function to an eigenfunction of my L operator? In any case What sort of result is to be expected of the corresponding eigenvalue? nothing? 0? Or what?
  3. May 25, 2012 #2
    you have several ways to work. Do you have the form of your ψ? if you do try writting it in the form of [SOMETHING that Lz cannot see]*[Eigenfunctions of Lz], which are the spherical harmonics Y[l,m].
    try thinking in the same way you would, if you had ψ= Σ αη φη(χ) and were asked for energy Ek....
    φη(χ) eigenfunctions of Hamiltonian.
  4. May 25, 2012 #3
    Yes i see what you meen, i was thinking of it the wrong way. The function is in fact already given in a manner where it's ([itex]\phi[/itex],[itex]\theta[/itex])-dependence can easily be separated from its r-dependance. so all i have to do is calculate clm =<lm|Y> for whatever Y[l,m] corresponds to the desired eigenvalue of Lz and then square that c wich would give the probability? Specificaly <l0|Y> for 0 and so on.
    But there are allot of eigenfunctions that would correspond to m = 0, would these all give me the same coefficient c?
    Furthermore as i understand it, the only way to obtain a value for Lz is if it's possible to separate the ([itex]\phi[/itex],[itex]\theta[/itex])-dependence so that i can be sure that this part is a linear combination of the spherical harmonics? Or can i deduce this in any other way? Actually how can i ever be sure that the function is at all a linear combination of the Y[l,m] ?
  5. May 25, 2012 #4
    if you have for example- I will denote Y[l,m]-
    Y[1,0], Y[0,0]
    both will participate in giving you m=0.
    if the one is 1/3 and the other is 1/3, then the total probability will be 2/3 :)
    Generally you can find it by:
    |<Your wanted state | ψ>|2
    using dirac's notation since I see you used it too...
    eg
    |<l 0|ψ>|2 will give you the possibility of your state ψ to fall (to be) on the state
    |l 0> it's like seeing |ψ>,|l,0> as vectors, and taking the inner product of them gives you the projection of one over the other.
    writing the above in integral form (going to the {r} representation):
    |∫Y*[l,0] ψ(r) d3r|2
    how did I do this?
    I used that I= ∫|r><r|d3r
    <l 0|I|ψ>= ∫<l 0|r><r|ψ>d3r= ∫<r|l 0>*<r|ψ>d3r = ∫Y*[l,0] ψ(r) d3r
    Now since you can always write ψ(r)= R(r) Y(θ,φ) you will have that R(r) is not seen by the Y* but Y* sees the Y[l,m](θ,φ)s you have in your state, leaving only those that have the same quantum numbers as it alive (orthogonal and normalised)
    how can you be sure that the function is a linear combination of the Y[lm]?
    Because they form a complete set of basis of your space (which is the space of θφ), so you can form out of them all possible states.
  6. May 25, 2012 #5
    Very neat explanation, thank you so much it really helps allot!
