Where is Your Home Losing Heat? Practical Methods for Measurement
In summary, an expert summarizer would say that to measure where a home is losing heat, you should measure overall heat loss, measure the number of hours of heat used during the month of February, and calculate the savings in years to come.
cesiumfrog
2,010
What is the most practical method of measuring where a home is losing heat?
The idea is that these measurements would be the first step in calculating the most cost-effective improvement, deciding whether to increase insulation in ceiling, walls or floor, to upgrade to double glazed windows or thicker curtains or just to seal minor drafts.. and on what timescale it might be cheaper to just install more powerful gas heating instead.
Science news on Phys.org
You won’t need to actually measure loss of each component because calculations will be accurate enough. You should measure overall heat loss, however, so you can plot your progress. Invest in an electronic thermostat that also displays the number of hours that your furnace is on per day and cumulatively from the time you reset the counter. Establish a baseline measurement, such as the number of hours of heat used during the month of February, and record the average daily temperature (it’s available on your energy bill) as well as the average daily temp inside your house. This will allow you to calculate the savings in years to come.
To figure out where to put your money and effort, calculate heat loss through each part of your home. Charts like
http://coloradoenergy.org/procorner/stuff/r-values.htm" [Broken]
give you the insulating efficiency (R-value) of different building materials, from which you calculate heat flux as
[tex]\dot{Q}=A(T_{outside}-T_{inside})/{Rvalue}[/tex]
where A is the area.
Example; I bought an old house in Colorado that had a 7’x9’ single pane sliding glass door with a highly conductive aluminum frame. The window was iced over most of the winter and the family room was uninhabitable. If the average R-value was about 0.6 and the daily average difference between indoor and outdoor was 30F (mild winter), then
[tex]\dot{Q}[/tex]=3150 Btu/hr. Sorry about the British units but that’s what’s used in the US HVAC and energy industries...
I installed a double-pane Low-E French door assembly with insulating shades, R-value about 3.3, so the savings is about 2.5kBtu/hr or 1.8e6Btu/month. My gas furnace is about 82% efficient (value available from the manufacturer) for a savings of 22 therms or $15-25 per month (natural gas prices vary from year to year) from just this one item. We would have done this upgrade for aesthetic reasons anyway, but with this kind of calculation I could determine the benefit (and also balance what sort of window with how much insulation versus cost).
Here are the rules of thumb:
1. Seal all drafts first. They are the biggest winners, while conversely if you don’t take care of them they’ll undo the effectiveness of any other improvements. Many of the biggest ones are hidden; for instance, the vertical chase of each “wet wall” (space for pipes behind your tubs and showers) is usually open to the attic.
2. Next take care of the most egregious offenders, like the window discussed above.
3. Next go from top to bottom.
a. Attic is a huge area and is easy to upgrade. Roll out new unfaced (so they breathe) R-25 fiberglass batts to bring the thickness to around 12 inches (R-38). Fiberglass is so cheap that this is a big win.
b. Next do windows, and garage walls (insulate and drywall) and door (insulated unit) if you have rooms above.
c. Can’t do much with walls unless you want to demolish the house. R-15 is typical for wall with 2x4 studs, R-11 insulation, drywall inside and wood sheathing outside.
d. Last in effectiveness is under-floor insulation.
4. You mention a more powerful furnace; if you insulate your house, you may get by with a smaller one instead, as I did. Upgrading the furnace will save money if existing furnace is old and inefficient. New furnaces are 80+ to 90+% efficient compared to 60-70% for 30 years ago.
The cold rooms in my house are now comfortable and the furnace rarely turns on unless in gets really cold outside. The calculations predicted pretty well the energy savings I actually observed (this isn’t rocket science after all…)
You can get more sophisticated later if you want. I've measured the thermal time constant of my home (it's now about 40 hours), the effective heat capacity, etc. These are amusing for a physicist, but the simple equation and chart above are all you really need.
Have fun!
This one can be huge.
I cut my oil usage about 50% for a sheet of foam board, a bit of that foaming sealant stuff and about a half hour of time.
Sealed off the opening into the attic.
Total cost < $10.
I found it because I was in the attic on a -20F day.
All of a sudden I realized, I'm warm :uhh:
Infiltration is also the most difficult/inaccurate to calculate. And it really is a huge problem even if it is only a little bit of air because of the heat content difference.
For the calculations, the easiest way to do it would be with software - and with the trial version of a program like this, it'll give you heat loss for a single zone, doubly easy because you can pick the type of wall/window and it'll tell you the R value - no need to calculate it yourself.
For me, my front door doesn't close perfectly flush, so I added some caulking foam where there were small gaps and now I can't notice a draft when I run the back of my hand along the seal. Also, my sidedoor mail box was extremely leaky, so I applied the same foam to it and voila, instant savings. Finally, if you have the money, consider upgrading your windows to double windows with argon in the spacing. They are fairly cheap and the heat savings are enormous.
None of the above actually answer the question...
I like Mr Cesium would be interested in measuring the actual highest loss from my house rather than the theoretical or most apparent.
For example I have replaced the 80's aluminum windows in my house with Victorian Sashes to bring the house back to how it should be. I've also taken out the nasty carpet that has been down since the 50's (I know that by the cigarette cards and newspaper I found underneath) and stripped the floor boards.
Now is it more cost effective to seal my windows during the winter, or pack the floor void with insulation. i.e block the draft in or the draw out
1st cheap, 2nd expensive.
And that is just in one room. I've tried using smoke matches to track the drafts with limited success and my budget doesn't streatch to a thermal imager.
Is it possible to bodge an old ccd to respond more in the infra red?
A digital camera with the first lens filter removed will be more receptive to infra red. For actual measurement, there are companies which specialise in thermal imaging (thermography) who will report for you on which areas of the property are losing how much heat. I've found these services to have been extremely informative in the past.
A calibrated thermal imaging camera will tell you local temperature but you'll still need to use models of conduction, convection, etc. to calculate heat loss from that. A thermal camera is mostly useful to identify areas that need attention rather than giving quantitative values.
Don't understand your question about windows, floors and drafts. Seal drafts first, as well as you can. If you can't feel any leaks in winter and don't see smoke sucked or blown, then you're doing fine. Next increase insulation in attic, then windows. Don't overlook value of insulating shades/curtains (honeycombs are good, "Warm Window" shades which seal to the wall around the windows are best because they stop convection). Insulating floors is least effective, but if your floor is open and accessible anyway (eg., open joists reachable from crawlspace) then it's easy and cheap to add fiberglass batts. Hold them in place with metal spring-rods sold where the insulation is sold. The vapor barrier goes towards the damp side, which in the western US is usually the house side. I wouldn't insulate floors inside heated areas like between 1st and 2nd floors.
Maybe use a digital thermometer (omega.com or from RadioShack) and take measurements of the temperature of the various surfaces of the inside of your house. Measure the outside air temperature and, as a 1st approximation, take this as the outside temperature of all the surfaces of your house. Your heat transfer will be greatest through the surfaces having the temperature closest to the outside temperature.
I have one of the Black and Decker thermal leak detectors it works nice. Looking for cold spots from the inside or warm spots from the outside is effective. If you stick a couple fans in a door/window to lower the pressure in your house the detector will be more effective at showing infiltration spots by drawing cold air in through the holes.
That's not measuring though, that's detecting. To measure I suppose you could turn all your thermostats to something high (75-80F) and then kill the heat source when you get there. Then for each thermostat measure the temp over time. Using the delta T over time and the specific heat for air (and that you know your houses air volume) should give you your rate of heat loss in BTU/hr per zone. Then you can prioritize reducing the rate of heat loss zone by zone. Note that this rate is linear with the outside temp, if you factor out outside temp you get the heat loss coefficient which is probably the closest thing you can get to measuring a home's heat loss.
I came here after a google search.
I had the idea of lowering my thermostat 5 degrees and note how long it took to turn on again.
But my biggest problem seems to be comparing it to data that I haven't found yet.
I wanted to see my house compared to other houses.
Even if I calculated BTU/hr it's just a number in my head.
You can use your existing furnace to calculate heat loss, providing you know its efficiency with a duty cycle other than 100%.
You need your Heating Degree Days for a month, your fuel usage for that month and your Outside Design Temperature to a 95% or 99% level.
My spreadsheet that does this is almost done.
What is home heat loss?
Home heat loss refers to the amount of heat that escapes from a home's interior to the outside. This can occur through various channels such as walls, windows, doors, and the roof, and can result in higher energy bills and discomfort for the occupants.
Why is it important to measure home heat loss?
Measuring home heat loss can help homeowners identify areas where heat is escaping and make necessary improvements to increase energy efficiency and reduce energy costs. It can also help determine the overall energy efficiency of a home and identify potential areas for improvement.
How is home heat loss measured?
Home heat loss can be measured through a variety of methods, including thermal imaging, blower door testing, and infrared thermography. These techniques can help identify areas of heat loss and determine the magnitude of the problem.
What factors contribute to home heat loss?
Several factors can contribute to home heat loss, including inadequate insulation, air leaks, and poor window and door seals. Other factors may include the type and age of the home, the climate, and the heating system used.
Can home heat loss be prevented?
While some degree of home heat loss is inevitable, there are steps that homeowners can take to reduce it. These include improving insulation, sealing air leaks, upgrading windows and doors, and using energy-efficient heating systems. Regular maintenance and upkeep of a home can also help prevent heat loss.
  • Computing and Technology
13K
  • General Discussion
