Measuring the speed of light with chocolate and a microwave oven
In summary: I was just expecting too much?)In summary, this friend teaches high school physics and tells me that they use this method to measure the speed of light. He explains that it can also be used to measure the frequency of the microwave, which is not as well known as c. He also notes that there is a big conceptual error in the approach, as the EM waves are assumed to be traveling in a horizontal plane. However, if you want to explore the experiment further you can measure the height, width, and depth of the oven and see if you get different results.
Science news on Phys.org
It could also be used to measure the frequency of the microwave, which is not as well known as c.
The method, of course, uses the fact that someone else measured the frequency of the microwave radiation. It's just an alternative way of measuring / knowing time.
I think that's splendid. What a great way to engage all chocolate lovers in the experimental method!
Cheese lovers, too! I've seen http://www.bbc.co.uk/mediacentre/proginfo/2012/46/dara-o-briains-science-club.html instead of chocolate.
from the OP's link:
Edit: when I made this measurement I forgot that I was measuring peaks of a standing wave which are half the wavelength of the microwave. So really, you should find the distance between the soft spots and multiply by 2 to get the wavelength. Thanks, Lord Axil. Somehow I must have missed a soft spot when measuring, which automatically corrected this factor of two.
More likely, he didn't realize his method was wrong in principle, but he got lucky and two errors canceled out.
The big conceptual error is assuming that the EM waves are traveling in a horizontal plane, so you can assume the distance between the spots = the wavelength (or half a wavelength, if you don't like the answer you got the first time!). The only "waves" that will produce heat spots in a fixed location are standing waves, and in a rectangular box like a typical microwave the standing waves are three dimensional. They can be very complicated - the wave can reflect off the walls, roof and floor of the box and make several "orbits" around the box before it repeats. What you are measuring is only a slice cut through that 3-D wave pattern. If you want to explore this further, it might be interesting to repeat the experiment at several different heights from the floor to the top of the oven, and compare the different patterns you get. Make sure you measure the positions of the spots relative to the sides of the oven, so you can "stack up" the different layers correctly.
The "real" wavelength inside the oven is something like ##\sqrt{kx^2 + ly^2 + mz^2}/n##, where x y and z are the width, height, and depth of the oven, and k,l,m,and n are four unknown integers. If you knew the values of k,l,m, and n, you could relate that to the pattern of spots you measured. The only problem is that you don't know what the integers were.
AlephZero said:
from the OP's link:
The big conceptual error is assuming that the EM waves are traveling in a horizontal plane, so you can assume the distance between the spots = the wavelength (or half a wavelength 1/2, if you don't like the answer you got the first time!). The only "waves" that will produce heat spots in a fixed location are standing waves, and in a rectangular box like a typical microwave the standing waves are three dimensional. They can be very complicated - the wave can reflect off the walls, roof and floor of the box and make several "orbits" around the box before it repeats. What you are measuring is only a slice cut through that 3-D wave pattern. If you want to explore this further, it might be interesting to repeat the experiment at several different heights from the floor to the top of the oven, and compare the different patterns you get.
The "real" wavelength inside the oven is something like ##\sqrt{kx^2 + ly^2 + mz^2}/n, where x y and z are the width, height, and depth of the oven, and k,l,m,and n are four unknown integers. If you knew the values of k,l,m, and n, you could relate that to the pattern of spots you measured. The only problem is that you don't know what the integers were.
That's pretty much the argument in the link I posted (he has some nice pictures to go along with it). Basically, it seems like this experiment only "works" because there will usually happen to be some hot spots whose distance apart is at least in the right order of magnitude, and then you can increase your precision either by hand-wavy measurements or by adding in factors of two as needed. :D
(I'll admit, though, I was kind of disappointed when I found out this experiment doesn't really work... it was one of my favourites in high school.)
posts 6,7 good insights...
I almost didn't post the link wondering about such...I was thinking reflections but wondered if there was some way manufacturers suppress them...then decided against that since it would seem to dimish delivered power [efficiency]...already not great...and it seems there are metal interior walls so anything outside would seem to have minimal effect.
What is the purpose of measuring the speed of light with chocolate and a microwave oven?
The purpose of this experiment is to demonstrate the concept of the speed of light and how it can be measured using everyday materials.
How does chocolate and a microwave oven help in measuring the speed of light?
The chocolate is used as a medium to create a waveguide, which is a material that can confine and direct waves. The microwave oven produces microwaves, which act as light waves in this experiment, and are directed through the chocolate waveguide to measure their speed.
What is the process of measuring the speed of light with chocolate and a microwave oven?
The process involves placing a bar of chocolate in a microwave oven and heating it until it starts to melt. The melted chocolate will create a waveguide, and the microwaves from the oven will travel through it. By measuring the distance the microwaves travel and the time it takes, we can calculate the speed of light.
Is it possible to get an accurate measurement of the speed of light using this method?
While this experiment may not produce an exact measurement of the speed of light, it is a fun and educational way to understand the concept and get a rough estimate of the speed of light.
Are there any safety precautions to take when conducting this experiment?
Yes, it is important to handle the hot chocolate and microwave oven with caution to avoid burns. It is also recommended to use a microwave-safe container for the chocolate and to follow the manufacturer's instructions for operating the microwave oven.
  • Optics
  • Electrical Engineering
