Measuring torque
  1. Nov 26, 2014 #1
    hi
    i need to perform the experiment described in this link
    http://www.phywe.com/index.php/fuseaction/download/lrn_file/versuchsanleitungen/P2430400/e/P2430400.pdf [Broken]
    so i need to measure the torque
    in the experiment they use Torsion dynamometer to do the job
    but i need to measure the torque without this device
    how can i do this manually?
    2. Relevant equations
    τ = m × B = mBsinθ
    3. The attempt at a solution
    i really don't have a good idea how to perform this but i may suggest the following ways:
    we may use the equation:
    τ=Iα
    α is the angular acceleration and I is the inertia moment
    but i think there is a problem with this because the torque is not constant but it change with time
    because the angle between the field and the moment changes in time
    so i don't really understand how this is works (what τ exactly they measure?)
    another way is to attach a spring to the loop so there is anothe torque (in the opposite direction) that acts on the loop
    therefore at equilibrium the magnetic torque will be the same as the spring torque
    m × B = kx × r
    therfore the torque i need is
    τ=kx × r
    and these quantities i can measure
    please give me your opinions or better ideas to measure the torque
    thanks in advance
  3. Nov 26, 2014 #2
    haruspex
    The spring sounds good to me, but there are some practical difficulties.
    The torque will be small, so you want a very light, stretchy spring. To prevent the loop twisting out of the vertical, I suggest two identical springs, one attached to each side of the loop. If the springs are ferrous, you'll need to make sure they are well outside the magnetic field, attached by long thin strings to the loop.
    I assume you want multiple readings, at different rotation angles. You can move the springs closer/further away to adjust the balance point.
  4. Nov 26, 2014 #3
    thank you very much.. i will take your notes into consideration
  5. Nov 26, 2014 #4
    haruspex
    Forgot to mention... you'll need to take into account the angle that the strings/springs make to the plane of the loop.
  6. Nov 26, 2014 #5
    you mean in the expression kx × r = kx⋅r⋅sinβ right?
  7. Nov 26, 2014 #6
    haruspex
    Yes.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Measuring torque
  1. Torque and such (Replies: 18)
Loading...
