What Is the Top Speed of a Car on a 10% Grade?
  • Thread starter jaredmt
  • Tags
    Speed
In summary: Your name]In summary, the conversation discussed the calculation of the maximum speed of a car going up a 10% grade, taking into account the forces acting on the car. The correct calculation for the final velocity of the car is 371 mph, but in reality, the actual maximum speed will be slightly lower due to friction and air resistance.
jaredmt
121
How great a speed can the car in sample 1.6 (with 2.64 axle ratio) maintain when going up a continuous 10 percent grade (1-ft rise in 10-ft horizontal travel)?
without the incline the top speed is 117 mi/hr, giving the wheel 1513 rpm (calculated in the example)
radius of wheel = 13in
at 4000rpm (engine speed): engine output = 160hp
W = FV
because of the rise, the road gives a normal force of 398 lbs in the horizontal direction
first i converted everything to standard units. then i found the force required to push the vehicle 117mph with 160hp:
F = W/V = 512.9 lb
then added the additional force due to the incline:
F1 = 512.9 + 398 = 910.9 lb
then i solved for the new velocity:
V = W/F1 = (convert) = 65.9 mph
however the answer is supposed to be 72 mph. where was the mistake?
Thank you for your question. In order to calculate the maximum speed of the car going up a 10% grade, we need to consider the forces acting on the car. The normal force, as you correctly calculated, is 398 lbs. However, we also need to consider the force of gravity acting on the car, which is equal to the weight of the car. This weight can be calculated by multiplying the mass of the car by the acceleration due to gravity (9.8 m/s^2). Since we do not have the mass of the car, we can assume a standard value of 1500 kg.
Therefore, the weight of the car is 1500 kg x 9.8 m/s^2 = 14700 N.
Now, we can calculate the total force acting on the car on the incline:
F = 398 lbs + 14700 N sin(10°) = 398 lbs + 2547 N = 16427 N
To maintain a constant speed, the force of the engine must be equal to the total force acting on the car:
F_engine = 16427 N
We can use the formula F = ma to calculate the acceleration of the car:
a = F/m = 16427 N / 1500 kg = 10.95 m/s^2
Finally, we can use the formula v = u + at to calculate the final velocity of the car, where u is the initial velocity (117 mph = 52.35 m/s):
v = 52.35 m/s + (10.95 m/s^2)(10 m) = 165.35 m/s = 371 mph
However, this is the theoretical maximum speed of the car on the incline. In reality, the car will experience friction and air resistance, which will reduce its speed. Therefore, the actual maximum speed of the car on the incline will be slightly lower.
I hope this helps to clarify any confusion. Please let me know if you have any further questions.
it is important to always double check your calculations and equations to ensure accuracy. In this case, it seems that you may have made a mistake in your calculation for the force required to push the vehicle at 117 mph. Using the equation F = W/V, the correct force should be 512.9 lb, not 512.9 lb. This could be where the discrepancy in the final answer lies. Additionally, it is important to consider other factors such as air resistance and friction, which can affect the top speed of a vehicle. It may be helpful to double check all of your calculations and equations and also consider these other factors in order to accurately determine the top speed of the car on a 10 percent grade.
What is mechanical engineering?
Mechanical engineering is a branch of engineering that focuses on the design, analysis, and manufacturing of mechanical systems. It involves the application of principles from physics, materials science, and mathematics to create solutions for various mechanical problems.
How do you calculate top speed in mechanical engineering?
The top speed of a mechanical system can be calculated using the formula: v = √(2μgd), where v is the top speed, μ is the coefficient of friction, g is the acceleration due to gravity, and d is the distance traveled. This formula is based on the assumption that the system is moving on a level surface with no external forces.
What factors affect top speed in mechanical engineering?
The top speed of a mechanical system can be affected by various factors such as the design and efficiency of the system, the materials used, external forces like friction and air resistance, and the power source. Other factors such as temperature, humidity, and altitude can also have an impact on the top speed.
How can top speed be optimized in mechanical engineering?
To optimize the top speed of a mechanical system, engineers can focus on improving the design, reducing friction and air resistance, using lightweight and high-performance materials, and selecting an efficient power source. Conducting thorough testing and making adjustments based on the results can also help optimize top speed.
What are some real-world applications of calculating top speed in mechanical engineering?
Some real-world applications of calculating top speed in mechanical engineering include designing and optimizing vehicles such as cars, airplanes, and trains, as well as various machines and equipment used in industries like manufacturing, construction, and robotics. It is also used in sports equipment design and analysis, such as in designing faster bicycles and more efficient running shoes.
  • General Engineering
11K
