Homework Help: Mechanical Energy problem
  1. Mar 29, 2013 #1
    A 1.2 kg dynamics cart is rolling to the right along a horizontal lab desk at 3.6 m/s, when it collides head on with a spring bumper that has a spring constant of 2.00 * 10^2 N/m.
    a) Determine the maximum compression of the spring
    b) Determine the speed of the cart at the moment that the spring was compressed by 0.10 m.
    2. Relevant equations
    E mechanical = E potential + E kinetic
    E kinetic = 1/2 m v^2
    E elastic = 1/2 k x^2
    E gravitational = mgh
    3. The attempt at a solution
    a) I got 0.28 m, and the book agrees.
    b) The answer should be 1.3 m/s. Here's what I get:
    Eg is constant, because the height doesn't change. Equal is:
    Et = Ee + Ek
    In the previous solution, i set Ee2 + 0 = Ek1 + 0 since before there is no elastic energy and afterwards there is no kinetic energy
    So Et = 1/2 * 2 * 10 ^2 N/m * 0.28 ^ 2 m ^2 = 7.84 joules
    Et - Ee = Ek
    7.84 J - 1/2 * 2 * 10^2 N/m * 0.10^2 m^2 = Ek = 6.84 J
    1/2 * 1.2 kg * v^2 = 6.84 J
    sqrt(6.84 / 1.2 kg / 0.5) = v^2 = 11.4 m^2 / s^2
    Square rooted I get 3.4 m/s
    The book says I'm doing b wrong, but I don't understand what I did wrong, or if the book is wrong.
  3. Mar 29, 2013 #2
    I'm getting the same answer as you.
  4. Mar 29, 2013 #3
    Hello !!!
    Do not worry. You are correct and if book does not concur with you, its wrong.
    I get 3.36 m/s which is approximately same as your answer.
  5. Mar 29, 2013 #4
    haruspex
    Fwiw, you can get the book answer by making the mistake of setting the KE equal to the PE when the spring is compressed .1 m.
Have something to add?
Draft saved Draft deleted
