1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Mechanical energy
  1. Jan 20, 2007 #1
    lzh
    A 0.5 kg bead slides on a curved wire, starting
    from rest at point A as shown in the figure.
    The segment from A to B is frictionless, and
    the segment from B to C is rough. The point
    A is at height 6.9 m and the point C is at
    height 1.6 m with respect to point B.
    The acceleration of gravity is 9.8 m/s^2 :
    [​IMG][/PLAIN] [Broken]
    the image for this problem is fig.2
    If the bead comes to rest at C, find the change
    in mechanical energy due to friction as it
    moves from B to C. Answer in units of J.
    2. Relevant equations
    mgh=energy of grav.
    Force*displacement=diss. energy
    3. The attempt at a solution
    First, I set mgh at point A to mgh at C + diss energy:
    (.5)(9.8)(6.9)=.5(9.8)+diss.
    diss=26J
    the answer above is not right, am i misunderstanding the question?
  3. Jan 20, 2007 #2
    arildno
    Dearly Missed
    Well, isn't the height at C 1.6m above B??
    Remember, though that the change of mechanical energy is NEGATIVE.
  4. Jan 20, 2007 #3
    lzh
    oh, thanks alot!
  5. Jan 20, 2007 #4
    lzh
    since i have fig.1 as well, I might as well post another one of my problem:
    A bead slides without friction around a loop-
    the-loop. The bead is released from a height
    of 9.4 m from the bottom of the loop-the-loop
    which has a radius 2 m.
    The acceleration of gravity is 9.8 m/s2 :
    What is its speed at point A? Answer in
    units of m/s.
    3.Work
    this is basically the same as the first problem, and mass isn't needed because it ends up canceling.
    so:
    mgh=.5mv^2+mgh <-there is also grav. energy, because A is not the lowest
    gh=.5v^2+gh
    (9.8)(9.4)=.5v^2+9.8(4)
    v=10.3m/s
    but that answer is wrong. I'm sure that i have the equation set out right, because at point A kinetic energy is transferred to grav. potential energy.
  6. Jan 20, 2007 #5
    you did some thing that does not make logical sense. take a look at your plus/minus signs.
  7. Jan 20, 2007 #6
    lzh
    so you are saying that one of the value that i plugged in should've been negative?
  8. Jan 20, 2007 #7
    yep. But don't just change it without understanding why. after it falls, it goes up 4 meters--not down.
  9. Jan 21, 2007 #8
    lzh
    i figured out what i did wrong... I rounded wrong. I was off by more than 1% from the real answer, so Utexa's homework service rejected it.
  10. Jan 21, 2007 #9
    Those drawings are down in Latex?
  11. Jan 21, 2007 #10
    lzh
    no, I copied and edited them on paint :)
Similar Discussions: Mechanical energy
  1. Mechanical Energy (Replies: 3)
  2. Mechanical Energy (Replies: 2)
  3. Mechanical Energy (Replies: 12)
  4. Mechanical energy (Replies: 9)
  5. Mechanical Energy (Replies: 2)
Loading...
