How Do You Calculate Water Velocity and Pipe Diameter in Mechanical Engineering?
In summary: A2)A2 = 0.002012m^2To find the diameter, we can use the equation A = πr^2 and solve for r, which gives us a radius of 0.0283m or 28.3mm. So, the smaller internal diameter of the tapered section of pipe would be 56.6mm.In summary, to calculate the velocity of water in a pipe supplied with water at a rate of 0.5kg/s through a pipe of diameter 80mm, we use the equation m = PVA and find the velocity to be 100m/s. To calculate the smaller internal diameter of a tapered section of pipe that
Aaron9890
Mechanical principles engineering question help??
A boiler is supplied with water at a rate of 0.5 kg/s through a pipe of diameter 80mm
a) Calculate the velocity of the water in the pipe
b) Calculate the smaller internal diameter of this tapered section of pipe calculate the velocity to be 2.5 times greater than the entry velocity calculated earlier.
Assume density is 1000kg/m^3
a) m= PVA
b) V1A1=V2A2
a) Mass flow rate = 0.5kg/s
Velocity=?
Area = 5.03 x 10^-3
Density = 1000kg/m^3
so m=P1V1A1
V=P1XA1/m
V= (1000)x(5.03x10^-3) / 0.5kg/s = 10.06m/s
Thanks for anyone who attempts to help me, i really appreciate it as this is my last assignment of the year:)
Hello! I would like to help you with your question. Let's start by looking at the given information and equations you have provided.
For part a), you are correct in using the equation m = PVA to solve for the velocity. However, there is a slight error in your calculation. The area of a circular pipe is calculated as A = πr^2, where r is the radius of the pipe. In this case, the diameter is given as 80mm, so the radius would be 40mm or 0.04m. Thus, the correct area would be A = π(0.04)^2 = 0.00503m^2. Plugging this into the equation, we get:
m = P1V1A1
0.5kg/s = (1000kg/m^3)(V1)(0.00503m^2)
V1 = 100m/s
So, the velocity of the water in the pipe is 100m/s.
For part b), you are on the right track in using the equation V1A1 = V2A2. However, this equation assumes that the mass flow rate remains constant. In this case, we are trying to find the smaller internal diameter that will result in a velocity 2.5 times greater than the entry velocity. This means that the velocity will change, and thus, the mass flow rate will also change.
To solve this, we can use the continuity equation, which states that the mass flow rate at any point in a pipe must remain constant. So, we can set up the following equation:
m1 = m2
P1V1A1 = P2V2A2
We know the values for P1, V1, and A1 from part a). We are also given the value for V2, which is 2.5 times greater than V1. So, V2 = 2.5(100m/s) = 250m/s. We also know the density, which is given as 1000kg/m^3. The only unknown in this equation is A2, which is the area of the smaller internal diameter.
Solving for A2, we get:
P1V1A1 = P2V2A2
(1000kg/m^3)(100m/s)(0.00503m^2) = (1000
1. What is mechanical engineering and what are its principles?
Mechanical engineering is a branch of engineering that deals with the design, analysis, and manufacturing of mechanical systems. This includes understanding and applying principles such as mechanics, thermodynamics, fluid mechanics, and materials science to solve real-world problems.
2. What are the main applications of mechanical engineering?
Mechanical engineering has a wide range of applications, including the design and manufacturing of machines, vehicles, structures, and systems used in industries such as automotive, aerospace, energy, and healthcare. It also plays a crucial role in the development of new technologies such as robotics, renewable energy, and nanotechnology.
3. Can you explain the concept of mechanical advantage in simple terms?
Mechanical advantage is the ratio of the output force generated by a machine to the input force applied to it. In other words, it is a measure of how much a machine can amplify force, allowing us to do more work with less effort. This concept is essential in understanding the efficiency and performance of mechanical systems.
4. How do mechanical engineers use computer-aided design (CAD) software?
CAD software is a crucial tool for mechanical engineers as it allows them to create and modify detailed 3D models of mechanical components and systems. This helps in visualizing and testing designs, identifying potential flaws, and optimizing the performance of the final product before it is physically built.
5. What are some common challenges faced by mechanical engineers?
Some common challenges faced by mechanical engineers include finding solutions to complex and diverse problems, ensuring the safety and reliability of designs, and keeping up with the rapidly advancing technology. They also have to consider factors such as cost, materials, and environmental impact while designing and manufacturing systems.
  • Mechanical Engineering
