Homework Help: Mechanics 1 vector help
  1. Aug 30, 2007 #1
    Hi.
    Could someone please help me with the following question? I've no idea how to begin
    Two ships P and Q are moving along straight lines with constant velocities. Initially P is at a point O and the position vector of Q relative to O is (6i + 12j) km, where i and j are unit vectors directed due east and due north respectively. The ship P is moving with velocity 10j km/h and Q is moving with velocity (-8i + 6j) km/h. At time t hours the position vectors of P and Q relative to O are p km and q km respectively.
    (a) Find p and q in terms of t.
    Thank you.
    Cathy
  3. Aug 30, 2007 #2
    learningphysics
    Does it say p and q are the magnitudes of the position vectors?
  4. Aug 30, 2007 #3
    berkeman
    Staff: Mentor
    You have initial position vectors and velocities. Express the relative motion in rectangular coordinates.
  5. Aug 30, 2007 #4
    No. It just says position vectors.
    Cathy
  6. Aug 30, 2007 #5
    What is the initial position vector for P?
    Cathy
  7. Aug 30, 2007 #6
    learningphysics
    Oh... I think I was just misunderstanding... So p is the final position of ship P and q is the final position of ship Q (all relative to 0)...
    you know that [tex]\vec{s} = \vec{s_{0}} + \vec{v}t[/tex]
    where [tex]\vec{s}[/tex] is the final position. Use this formula to find the final position of P and Q... treat P and Q as separate problems... one really has nothing to do with the other...
    So what is [tex]\vec{s_{0}}[/tex] and [tex]\vec{v}[/tex] for P?
    What is [tex]\vec{s_{0}}[/tex] and [tex]\vec{v}[/tex] for Q?
  8. Aug 30, 2007 #7
    learningphysics
    It is just 0. Or 0i + 0j.
  9. Aug 30, 2007 #8
    Oh, thanks very much. I understand now!
    Cathy
  10. Aug 30, 2007 #9
    learningphysics
    No prob.
  11. Aug 30, 2007 #10
    Oh yikes - I'm now stuck on these two parts!
    Could someone please give me some hints? I would really appreciate any help!
    Calculate the distance of Q from P when t = 3.
    Is t measured in seconds, minutes or hours?
    Calculate the value of t when Q is due north of P.
    Thank you.
    Cathy
  12. Aug 30, 2007 #11
    learningphysics
    t is in hours according to the question description... did you calculate the formulas for p and q?
    Do you have any ideas of how to approach the problem? Hint: Use your position formulas p and q
  13. Aug 30, 2007 #12
    Oh yeah, of course it is!
    Yup, I got p = 10jt and q = (6 - 8t)i + (6t + 12)j.
    Would it be possible to work out the displacement and then use v = d/t?
    Cathy
  14. Aug 30, 2007 #13
    learningphysics
    The formulas look good. Yeah, you need the displacement from P to Q. But you don't need velocity. You need distance... so get the distance from your displacement.
  15. Aug 30, 2007 #14
    Thanks so much.
    I got that the distance is 18 km.
    Am not sure how to do the next part, though.
    Could you please help?
    Thank you.
    Cathy
  16. Aug 30, 2007 #15
    learningphysics
    The distance looks good to me. :)
    For the next part. Use your displacement formula from P to Q which is in terms of t...
    Hint: you want to find the time when the i component of the displacement 0. when that happens, either Q is north or south of P. you should check the number you get to make sure Q is north and not south of P.
  17. Aug 30, 2007 #16
    Thanks for your help.
    I got that t = 0.75 hours.
    I'm not sure how to check the number to check that it is north and not south of P. Could you please explain this?
    Cathy
  18. Aug 30, 2007 #17
    learningphysics
    Cool. That's what I get.
    In your displacement formula from P to Q, when you substitute in t = 0.75, you should get a positive coefficient for j... that means that Q is north of P... if it was negative Q would be south of P.
    I get the displacement from P to Q at t=0.75 as q - p = 9j, so since 9>0 Q is north of P...
  19. Aug 30, 2007 #18
    Okay. I get it now!
    Thanks again for all your help.
    I really appreciate it! :-)
    Cathy
  20. Aug 30, 2007 #19
    learningphysics
    You're welcome. :smile:
Loading...
