Mechanics question
  1. Oct 12, 2007 #1
    Calculate the moment of the 90N force about point O for the condition theta=15 degrees.
    2. Relevant equations
    Moment= Force* perpendicular distance
    3. The attempt at a solution
    I am doing the first step
    Fx= 90sin theta
    Fy= 90costheta
    What i got was Moment= (Fx*0.8) + (Fy*0.6)= 72sintheta + 54costhetha
    When I looked at the worked solution, they got a -Fx*0.8, i dont understand how the negative sign came about. Can you help out? Thanks
  3. Oct 13, 2007 #2
    Astronuc
    Staff: Mentor
    Clockwise moments are consider +, counterclockwise moments are considered -. Righthand rule.
  4. Oct 18, 2007 #3
    minger
    You need to look at your units as well. As an early student, write your units out for everything. Degrees/radians are unitless. All you have right now is a force times a unitless quantity, your resultant is N. You need Nm, which means you need to still multiply by a distance.
    You were correct to take the sin/cos to find the horizontal and vertical components of the force, but you still need to multiply it by the distance from the center.
    So, for the vertical direction:
    M = -90N*cos(theta)*600mm*(1 m / 1000 mm) = x Nm
    As Astro said, negative because of sign convention. Do the same for the other component, making sure its in the direction that you think.
Similar Discussions: Mechanics question
  1. Mechanics Question (Replies: 2)
  2. Mechanical Question (Replies: 1)
Loading...
