- 51
Hi
Could someone please help me with some questions that I got wrong in an exam recently....
1. Avessel is partly filled with a liquid whose expansion coefficient is equal to the volume expansion coefficient of the vessel on heating the vessel the intermal available volume of space 1) increases 2) decreases 3) remains same
2. A man x is sitting at the rear end of a long compartment of a train running at constant horizontal velocity, tosses a coin to a person y who is near the front end of the compartment. The trajectory of the ball, as seen by y and a person z on the ground, will have : 1.) Equal vertical and horizontal ranges 2. ) equal vertical ranges but different horizontal ranges 3.) Different vertical and horizontal ranges
3. What is the velocity of efflux of kerosene from a tank in which the pressure is 4x10² N/m² above the atmospheric pressure. Density of kerosene is 800kg/m³. The orifice is at the bottom.............
4. The top of a lake frozen. Where the air in contact with the lake surface is at -13°C. The temperature of water at the bottom of the lake will be : (Answer given is -4degrees but i think it should be 4 degrees):surprised
