Understanding Rotational Mechanics: Finding Components of a Rotated Unit Vector
In summary, a rotation about the +z axis in a right handed coordinate system results in a 2D rotation about the x-y plane.
Genericcoder
131
Consider two cartesian coordinate system xyz and x` y` z` that initally concide. The x` y` z` undergoes three successive counterclockwise 45 rotations about the following axes: first, about the fixed z-axis;second, about its own x`-axis( which has been now rotated); finally, about its own z`-axis ( which has now been rotated);finally, about its own z`-axis (which has also been rotated). Find the components of a unit vector X in the xyz coordinate system that points along the direction of the x`-axis in rotated x` y` z` system.
Attempted solution
Let matrix A,B,& C denote the 3 rotation such that A denote the rotation 45 about z-axis,B rotation 45 about its x-axis,& C denote the matrix which has been rotated about its own z` axis.
A = [cos 45 sin 45 0]
[-sin 45 cos45 0]
[0 0 1 ]
B = [ 1 0 0 ]
[ 0 cos45 -sin45]
[ 0 sin45 cos45]
C = [cos45 sin45 0]
[-sin45 cos45 0]
[0 0 1]
I have them everything right but in my book it has in second B matrix it has
j . k` as -sin45 but why is that!?
I'm confused about what you are asking. Are you asking why it's then second row in the B matrix that has the negated value rather than the third?
Yes in the book its the answer for j.k` = -sin(45) instead of sin(45) even though its cos(90 - theta) = sin(theta)
or is their something I am missing?
There's an isomorphism consisting of rotating the three axes, z to x, x to y, y to z. This should map A to B.
Applying that to your A matrix gives
B = [ 1 0 0 ]
[ 0 cos45 sin45]
[ 0 -sin45 cos45]
Edit: on second thoughts, that's a rotation about the original x axis.
Ye I can see that coz cos(90 - theta) = sin(theta) thank you haru
And cos(90 + theta) = -sin(theta) so I was wondering do I have the other matrices right for A B and C? @ haru?
Talking about isomorphisms is perhaps a bit advanced for this Introductory Physics question.
The answer lies in the right hand rule. Set up a right handed coordinate system, with positive rotations indicated by the right hand rule. Now describe what happens with rotations about the various axes.
I'll start with rotation about the +z axis because that's equivalent to the canonical 2D rotation in the x-y plane. Here's a rotation about the z axis looks:
Notice that a positive rotation about the +z axis rotates the +x axis toward the +y axis and rotates the +y axis toward the -x axis:
[tex]\begin{aligned}
\hat x' &= \phantom{-}\cos \theta\,\hat x + \sin \theta\,\hat y \\
\hat y' &= -\sin\theta\,\hat x + \cos\theta\, \hat y \\
\hat z' &= \phantom{-\sin\theta\,\hat x + \cos\theta\,\hat y} + \hat z
\end{aligned}[/tex]
Writing the above in matrix form,
[tex]
\begin{pmatrix} \hat x' \\ \hat y' \\ \hat z' \end{pmatrix} =
\begin{pmatrix}
\phantom{-}\cos \theta & \sin \theta & 0 \\
-\sin \theta & \cos \theta & 0 \\
0 & 0 & 1
\end{pmatrix} \,\,
\begin{pmatrix} \hat x \\ \hat y \\ \hat z \end{pmatrix}
[/tex]
That matrix on the right? That's your matrix C.Next let's look at a rotation about the +x axis:
Here a positive rotation about the +x axis rotates the +y axis toward the +z axis and rotates the +z axis toward the -y axis:
\hat y' &= \phantom{-}\cos \theta\,\hat y + \sin \theta\,\hat z \\
\hat z' &= -\sin\theta\,\hat y + \cos\theta\, \hat z \\
\hat x' &= \phantom{-\sin\theta\,\hat y + \cos\theta\,\hat z} + \hat x
\end{aligned}[/tex]
[tex]
\begin{pmatrix}
1 & 0 & 0 \\
0 & \phantom{-}\cos \theta & \sin \theta \\
0 & -\sin \theta & \cos \theta
\end{pmatrix} \,\,
[/tex]
That matrix on the right? That's your matrix A.Finally, let's look at a rotation about the +y axis:
Here a positive rotation about the +y axis rotates the +z axis toward the +x axis and rotates the +x axis toward the -z axis:
\hat z' &= \phantom{-}\cos \theta\,\hat z + \sin \theta\,\hat x \\
\hat x' &= -\sin\theta\,\hat z + \cos\theta\, \hat x \\
\hat y' &= \phantom{-\sin\theta\,\hat z + \cos\theta\,\hat x} + \hat y
\end{aligned}[/tex]
[tex]
\begin{pmatrix}
\cos\theta & 0 & -\sin\theta \\
0 & 1 & 0 \\
\sin\theta & 0 & \cos \theta
\end{pmatrix} \,\,
[/tex]
That matrix on the right? That's your matrix B.
I took the above images from slide 63 of a set of tutorial slides presented at Siggraph 98:
http://www.sdsc.edu/~moreland/courses/Siggraph98/vrml97/slides/mt0000.htm
Thanks a lot DH that makes sense.
I have a question why do we have to multiply the matrix right to left instead of left to right to get the product for example in my example it is :
CBA to get the total rotated components.
What is mechanics rotation?
Mechanics rotation is a branch of physics that studies the motion of objects around a fixed axis or point.
What is the difference between linear and rotational motion?
Linear motion refers to the movement of an object in a straight line, while rotational motion is the movement of an object around a fixed axis or point.
What is the relationship between torque and rotational motion?
Torque is the measure of the force that causes an object to rotate around an axis. It is directly proportional to the angular acceleration of the object.
What is the moment of inertia in rotational motion?
The moment of inertia is a measure of an object's resistance to changes in its rotational motion. It depends on the mass and distribution of mass of the object.
How is angular velocity calculated in rotational motion?
Angular velocity is the rate of change of an object's angular displacement and is calculated as the change in angle over time. It is measured in radians per second.
