Meissner Effect: Levitating a Magnet & Lenz's Law
In summary, the Meissner effect is a phenomena that occurs when a magnet is placed over a superconductor. The current that is generated keeps existing forever, and is in proportion to the magnetic vector potential A. The Meissner effect is different from the induction of current by Faraday's law, which is due to the change in field.
cragar
2,552
When we see people levitate a magnet over a superconductor, Does the magnet cause electrons to flow in the superconductor and this creates a B field to hold up the magnet. Is this similar to lenz's law. And why does the stationary magnet cause electrons to flow, I thought we needed a change in magnetic flux to produce a voltage according to Faraday's law.
Any input will be much appreciated.
Someone has to have something on the Meissner effect.
come on know one has anything on this .
Nah, I'm pretty sure the magnet must drop a little bit before it can stop in a levitated state.
If it drops, it will create a current. The current will keep existing forever (as long as the material is superconducting) so the B field is about constant.
The Meissner effect is conceptually different from the current induced in an infinitely good conductor by Faradays law of induction. In a superconductor, the current is directly proportional to the magnetic vector potential A. That's called Londons equation.
Btw, not only superconductors show levitation in magnetic fields but in principle any diamagnetic substance. E.g. I have some high purity graphite which also floats over some permanent magnets.
interesting thanks for the answers, And I've also seen where they float a magnet over the superconductor and they turn it over and it still stays there. So does it like attract it and then repel it .
The reason why nobody is giving you good answers is because Meisner Effect is quite complicated. You need to understand a good deal of quantum mechanics and solid state theory to understand where it comes from and how it works.
The basic statement that arises from this is that magnetic field within a superconductor cannot change without destroying superconducting state. The later is only possible if you excite the superconductor to a higher energy state, so you have to input a certain amount of energy. You can do so by increasing temperature or increasing external field, for example.
From here, all of the properties follow. If you attempt to change external field, the current inside superconductor changes, canceling the external field. So if you move a magnet towards a superconductor, superconductor itself becomes a magnet that repels the one you moved closer. Hence, levitation. You can also pass critical temperature with some external field already present. Then this field becomes "frozen" in the superconductor, and you can later use it as a powerful magnet. Particle accelerators and magnetic resonance spectrometers often use this.
By the way, induction of current in superconductor has little to do with classical Faraday's effect, exactly because the field never changes. Since dB/dt inside superconductor is zero, so is the electric field created by Faraday's Law. The actual process is entirely Quantum, and has to do with effects of vector potential on electron wave function.
P.S. All of the above is valid for Type I superconductor, and not necessarily for Type II, which is a bit different.
Thanks K^2 for you answer , you seem to know a lot .
1. What is the Meissner Effect?
The Meissner Effect is a phenomenon in which a superconductor expels all magnetic fields from its interior. This results in the magnetic field lines being forced to flow around the superconductor, causing it to levitate.
2. How does the Meissner Effect allow for levitation of a magnet?
When a magnet is brought near a superconductor, the superconductor's electrons rearrange themselves to create an opposing magnetic field. This opposing field repels the magnet, causing it to levitate above the superconductor.
3. What is Lenz's Law and how does it relate to the Meissner Effect?
Lenz's Law states that the direction of an induced current will always be such that it opposes the change that caused it. In the case of the Meissner Effect, the superconductor's electrons create an opposing magnetic field to repel the magnet, thus following Lenz's Law.
4. Can any material exhibit the Meissner Effect?
No, the Meissner Effect only occurs in materials that are superconductors. These materials must be cooled to extremely low temperatures (usually below -200°C) to exhibit this effect.
5. What are some potential applications of the Meissner Effect?
The Meissner Effect has potential applications in transportation, such as using superconducting trains that can levitate above their tracks. It also has uses in the medical field, such as in MRI machines. Superconductors are also being studied for use in energy-efficient power transmission and storage systems.
  • Other Physics Topics
  • Atomic and Condensed Matter
