Melting point of 40% Sn and 60% Pb
In summary: Interspecific interactions are the kind of thing that happens when two different species of living things are put together in a lab --- typically they'll fight over resources or produce toxins that damage the other species.
Monique
Staff Emeritus
67
Who can calculate the meltingpoint for me of a mixture of metals with 40% Sn and 60% Pb?
Chemistry news on Phys.org
From first principles? Or, did you just want a value for the Sn-Pb eutectic?
Euhh, I have no clue what that means :) The substance I am asking for is soudage (a complete foreign word to me, I had to look it up in a dictionary)
The case is the following: my dad wants to solder (?) a .. euhh, thing with which you can scoop french fries out of the pan with .. euhh, not oil, frying greace (?). So he asked me what the melting point of the soudage is, since frying is done at high temperatures.
Boy, it is not always easy speaking English :O I am sorry :)
Ofcourse I am going to tell him that it is not smart to use a metal with 60% Pb on a utensil with which you make food, but I was wondering whether the principle works :)
I think the dictionary gave me the french word for some reason (soudage) I think it is just solder :) I thought something was wrong with that word :)
I looked it up myself (it was too late last night)
Is the answer as simple as 0.6 * 327.5 (Tm Pb) + 0.4 * 231.9 (Tm Sn)?
Which would be 289 oC.
French fries are fried at 165-190 oC so it would work :)
Sn-Pb is NOT an ideal mixture; go to http://www.tpub.com/steelworker1/57.htm for a phase diagram and brief description of the system behavior --- or to http://www.turbobraze.co.uk/alloysssa.htm for a list of compositions and m.p. ranges.
Bottom line? The eutectic temperature is 175-180 C, 60-40 has a m.p. range that starts at only a slightly higher temperature --- your daddy is looking for hot grease all over the kitchen. Brazing or silver-soldering is going to make for much happier results. (Plumbing shops should be able to steer you to decently priced Ag solders --- stronger, nicer to work with, more corrosion resistant, and easier cleaning in the kitchen.) The Pb toxicity issue isn't that big a deal unless he's planning on frying things with lots of acids or salt that might leave residues in the grease, corrode the Pb, then soak soluble lead into the next batch being cooked.
Ah! Thank you Bystander :)
But why is the eutectic temperature so much lower than the melting temperatures of the individual metals, and why is my little calculation so far off?
Pb mp = 372.5
Sn mp = 231.9
40/60 Sn/Pb eutectic temp 183-238
"Why" do positive and negative azeotropes exhibit b.p.s higher/lower than those of the pure components? Same situation, different phases --- solid-liquid solution equilibrium rather than vapor-liquid.
Melting points of even ideal mixtures aren't going to be a composition weighted average --- and, definitely not a mass/weight weighted average. The colligative properties of the components are going to control ideal mixture m.p.s, and interspecific interactions have to be taken into account for real mixtures.
Pb mp = 372.5
Sn mp = 231.9
I'll be picky and correct you here --- the eutectic is the specific composition at the lowest T on the phase diagram --- it can be considered the m.p. of a compound, Sn4Pb, and the compositions of both the liquid and solid phases are identical; the melting "range" for other compositions is the range of temperature over which the solid phase(s) melt to yield a liquid phase the composition of which varies as T changes.
Thank you for correcting me, I am more into the chemistry of biological rather than metallic molecules :)
What do you mean by colligative properties and interspecific interactions?
So are you saying that m.p. can only be measured and not calculated? For DNA there are algorithms with why the meltingpoint can be calculated, where it is the function of the number of A, C, G, Ts and also how many runs of GGGG there are for instance or AAAA.
Is there something like that for other compounds?
Colligative properties are those properties depending only upon concentrations of solutes in a solution --- clumsy wording --- for instance, you've run into osmometric determinations of molecular weights of quite a few biological molecules; dissolve a known weight of substance in some suitable solvent, determine the reduction in the solvent vapor pressure as a result of the solution process, and from knowledge of the solvent's colligative properties (determined from enthalpies of phase changes at particular temperatures plus a little van't Hoff magic) out pops the number of moles of solute in the solution. You've got the weight, now you know how many moles, and voila! a molecular weight. Same game for freezing point depression, osmotic pressure, and whatever else that's slipped my mind at the moment.
By interspecific interactions, I mean the various molecular interactions, in the solder case, tin with lead, and the intraspecific interactions tin-tin and lead-lead; these are non-zero, and yield some very interesting behaviors in mixed or multi-component systems.
Melting point is a measured property. Given a homologous series, say odd numbered (or even) straight chain saturated hydrocarbons, the melting points (and other physical properties) of missing (data-wise) members of the series can be interpolated from known data for higher and lower MW members. There are similar correlations for invariant structures subject to modifications of functional groups from limited sets --- the DNA vs. base pair game you mention. These are NOT based on any rigorous analysis of intermolecular potential functions. In principle, calculations of melting points and vapor pressures are possible; in practice, no one has the foggiest idea what an intermolecular potential function looks like, let alone how to handle it mathematically.
The DNA correlation depends upon probably hundreds to thousands of measurements; these have since been correlated to three independent variables, and since most DNA does not depart significantly from the ranges of base fractions for the original correlation, it works. I'd be very surprised if the correlation did NOT fail for "synthetic" DNAs of repeated short sequences, or the single base cases (except, a single base DNA can't be made to pair with itself in the helix), so make that single "base-pair" cases.
Thank you SO much Bystander, for explaining all that to me. It is much clearer to me now.
"The DNA correlation depends upon probably hundreds to thousands of measurements; these have since been correlated to three independent variables, and since most DNA does not depart significantly from the ranges of base fractions for the original correlation, it works. I'd be very surprised if the correlation did NOT fail for "synthetic" DNAs of repeated short sequences, or the single base cases (except, a single base DNA can't be made to pair with itself in the helix), so make that single "base-pair" cases."
You would NOT be surprised if the algorithms would fail for short synthetic DNAs? :) Actually, those algorithms were specifically made for short molecules (usually around 20 bp) in low concentration solutions. And single bases cannot 'melt' :) so no, it would apply there.
Now, I learned something --- they've played with short string syntheses for physical property measurements; in any case, application of the algorithm outside the ranges of base compositions, or chain lengths is getting into "iffy" territory.
The question came up in context other than PF regarding enthalpies, entropies, and free energies of formation of nucleic acids --- anybody got any decent measurements on these?
1. What is the melting point of 40% Sn and 60% Pb?
The melting point of an alloy composed of 40% Sn and 60% Pb is approximately 183°C (361°F). This is a eutectic alloy, meaning it has the lowest melting point of all possible compositions within the Sn-Pb system.
2. How does the melting point of 40% Sn and 60% Pb compare to pure Sn and Pb?
The melting point of this alloy is lower than both pure Sn (231.9°C or 449.4°F) and pure Pb (327.5°C or 621.5°F). This is due to the eutectic composition, which has a lower melting point than the individual components.
3. What factors affect the melting point of this alloy?
The main factors that affect the melting point of this alloy are the composition (percentage of Sn and Pb) and any impurities present. The presence of impurities can alter the melting point of the alloy, making it higher or lower than the expected eutectic point.
4. Can the melting point of this alloy be changed?
The melting point of this alloy is fixed at the eutectic point (183°C or 361°F) for the given composition of 40% Sn and 60% Pb. However, by changing the composition of the alloy, the melting point can be altered. For example, increasing the percentage of Sn will decrease the melting point, while increasing the percentage of Pb will increase the melting point.
5. What is the significance of knowing the melting point of this alloy?
The melting point of this alloy is important to know for various industrial applications, such as soldering and casting. It also helps in understanding the properties of the alloy, including its workability and strength at different temperatures. Furthermore, knowing the melting point can aid in the proper handling and use of the alloy to ensure its quality and effectiveness in different processes.
  • Chemistry
  • General Engineering
  • Chemistry
  • Materials and Chemical Engineering
42K
