- 1
1. Implement a new version of mergeSort() where 3 sorted lists (instead of 2) of about the same size are merged.
2. No equations
3. here is what i have so far:
2. No equations
Code:
public final class Sort
* Simple insertion sort.
* @param a an array of Comparable items.
public static <AnyType extends Comparable<? super AnyType>>
void insertionSort( AnyType [ ] a )
int j;
for( int p = 1; p < a.length; p++ )
AnyType tmp = a[ p ];
for( j = p; j > 0 && tmp.compareTo( a[ j - 1 ] ) < 0; j-- )
a[ j ] = a[ j - 1 ];
a[ j ] = tmp;
* Shellsort, using Shell's (poor) increments.
void shellsort( AnyType [ ] a )
int j;
for( int gap = a.length / 2; gap > 0; gap /= 2 )
for( int i = gap; i < a.length; i++ )
AnyType tmp = a[ i ];
for( j = i; j >= gap &&
tmp.compareTo( a[ j - gap ] ) < 0; j -= gap )
a[ j ] = a[ j - gap ];
a[ j ] = tmp;
* Standard heapsort.
void heapsort( AnyType [ ] a )
for( int i = a.length / 2; i >= 0; i-- ) /* buildHeap */
percDown( a, i, a.length );
for( int i = a.length - 1; i > 0; i-- )
swapReferences( a, 0, i ); /* deleteMax */
percDown( a, 0, i );
* Internal method for heapsort.
* @param i the index of an item in the heap.
* @return the index of the left child.
private static int leftChild( int i )
return 2 * i + 1;
* Internal method for heapsort that is used in
* deleteMax and buildHeap.
* @int i the position from which to percolate down.
* @int n the logical size of the binary heap.
private static <AnyType extends Comparable<? super AnyType>>
void percDown( AnyType [ ] a, int i, int n )
int child;
AnyType tmp;
for( tmp = a[ i ]; leftChild( i ) < n; i = child )
child = leftChild( i );
if( child != n - 1 && a[ child ].compareTo( a[ child + 1 ] ) < 0 )
child++;
if( tmp.compareTo( a[ child ] ) < 0 )
a[ i ] = a[ child ];
else
break;
a[ i ] = tmp;
* Mergesort algorithm.
@SuppressWarnings("unchecked")
void mergeSort( AnyType [ ] a )
AnyType [ ] tmpArray = (AnyType[]) new Comparable[ a.length ];
mergeSort( a, tmpArray, 0, a.length - 1 );
* Internal method that makes recursive calls.
* @param tmpArray an array to place the merged result.
* @param left the left-most index of the subarray.
* @param right the right-most index of the subarray.
void mergeSort( AnyType [ ] a, AnyType [ ] tmpArray,
int left, int right )
if( left < right )
int center = ( left + right ) / 2;
mergeSort( a, tmpArray, left, center );
mergeSort( a, tmpArray, center + 1, right );
merge( a, tmpArray, left, center + 1, right );
* Internal method that merges two sorted halves of a subarray.
* @param leftPos the left-most index of the subarray.
* @param rightPos the index of the start of the second half.
* @param rightEnd the right-most index of the subarray.
void merge( AnyType [ ] a, AnyType [ ] tmpArray, int leftPos, int rightPos, int rightEnd )
int leftEnd = rightPos - 1;
int tmpPos = leftPos;
int numElements = rightEnd - leftPos + 1;
// Main loop
while( leftPos <= leftEnd && rightPos <= rightEnd )
if( a[ leftPos ].compareTo( a[ rightPos ] ) <= 0 )
tmpArray[ tmpPos++ ] = a[ leftPos++ ];
else
tmpArray[ tmpPos++ ] = a[ rightPos++ ];
while( leftPos <= leftEnd ) // Copy rest of first half
while( rightPos <= rightEnd ) // Copy rest of right half
// Copy tmpArray back
for( int i = 0; i < numElements; i++, rightEnd-- )
a[ rightEnd ] = tmpArray[ rightEnd ];
* Quicksort algorithm.
void quicksort( AnyType [ ] a )
quicksort( a, 0, a.length - 1 );
private static final int CUTOFF = 3;
* Method to swap to elements in an array.
* @param a an array of objects.
* @param index1 the index of the first object.
* @param index2 the index of the second object.
public static <AnyType> void swapReferences( AnyType [ ] a, int index1, int index2 )
AnyType tmp = a[ index1 ];
a[ index1 ] = a[ index2 ];
a[ index2 ] = tmp;
* Return median of left, center, and right.
* Order these and hide the pivot.
AnyType median3( AnyType [ ] a, int left, int right )
if( a[ center ].compareTo( a[ left ] ) < 0 )
swapReferences( a, left, center );
if( a[ right ].compareTo( a[ left ] ) < 0 )
swapReferences( a, left, right );
if( a[ right ].compareTo( a[ center ] ) < 0 )
swapReferences( a, center, right );
// Place pivot at position right - 1
swapReferences( a, center, right - 1 );
return a[ right - 1 ];
* Internal quicksort method that makes recursive calls.
* Uses median-of-three partitioning and a cutoff of 10.
void quicksort( AnyType [ ] a, int left, int right )
if( left + CUTOFF <= right )
AnyType pivot = median3( a, left, right );
// Begin partitioning
int i = left, j = right - 1;
for( ; ; )
while( a[ ++i ].compareTo( pivot ) < 0 ) { }
while( a[ --j ].compareTo( pivot ) > 0 ) { }
if( i < j )
swapReferences( a, i, j );
else
break;
swapReferences( a, i, right - 1 ); // Restore pivot
quicksort( a, left, i - 1 ); // Sort small elements
quicksort( a, i + 1, right ); // Sort large elements
else // Do an insertion sort on the subarray
insertionSort( a, left, right );
* Internal insertion sort routine for subarrays
* that is used by quicksort.
void insertionSort( AnyType [ ] a, int left, int right )
for( int p = left + 1; p <= right; p++ )
int j;
for( j = p; j > left && tmp.compareTo( a[ j - 1 ] ) < 0; j-- )
a[ j ] = tmp;
* Quick selection algorithm.
* Places the kth smallest item in a[k-1].
* @param k the desired rank (1 is minimum) in the entire array.
void quickSelect( AnyType [ ] a, int k )
quickSelect( a, 0, a.length - 1, k );
* Internal selection method that makes recursive calls.
* @param k the desired index (1 is minimum) in the entire array.
void quickSelect( AnyType [ ] a, int left, int right, int k )
for( ; ; )
if( i < j )
else
break;
if( k <= i )
quickSelect( a, left, i - 1, k );
else if( k > i + 1 )
quickSelect( a, i + 1, right, k );
private static final int NUM_ITEMS = 1000;
private static int theSeed = 1;
private static void checkSort( Integer [ ] a )
for( int i = 0; i < a.length; i++ )
if( a[ i ] != i )
System.out.println( "Error at " + i );
System.out.println( "Finished checksort" );
public static void main( String [ ] args )
Integer [ ] a = new Integer[ NUM_ITEMS ];
a[ i ] = i;
for( theSeed = 0; theSeed < 20; theSeed++ )
Random.permute( a );
Sort.insertionSort( a );
checkSort( a );
Sort.heapsort( a );
checkSort( a );
Sort.shellsort( a );
checkSort( a );
Sort.mergeSort( a );
checkSort( a );
Sort.quicksort( a );
checkSort( a );
Sort.quickSelect( a, NUM_ITEMS / 2 );
System.out.println( a[ NUM_ITEMS / 2 - 1 ] + " " + NUM_ITEMS / 2 );
