Meteorological balloon
  • Thread starter chawki
chawki
506
A meteorological balloon has volume of 20.0 m3 and a weight of 10.5 kg (gas included).
The density of the air is 1.18 kg/m3 and acceleration of gravity 9.81 m/s2
What amount of cargo in kg can the balloon lift?
Can you please advise about the starting point, it has certainly something to do with the density of air.
I'm using the principle PV=nRT but it's not taking me any further
Answers and Replies
gneill
Mentor
20,945
2,886
Think buoyancy.
chawki
506
you're explaining me something difficult with something more difficult...some laws would be nice.
I think that to be able to lift some weight, the density inside the ballon should be greater than the air density...but then ?
gneill
Mentor
20,945
2,886
If the density inside the balloon were greater than that of air, then the balloon would be heavier than air and it would fall to the ground.
This is a buoyancy problem. I'm afraid there's no escaping it! You'll need to review your notes or text on the subject.
The balloon's volume is displacing a certain weight of air, replacing it with its own (less dense) weight of gas + balloon.
chawki
506
yes i was wrong about the density inside the ballon...it should be less than air of course..we heat air inside the ballon so that the density decrease.
you know, it would be nice to see the solution or half of it and i will try to understand it by my own..it have always worked for me.
but thank you for your help.
chawki
506
can someone tell me how can we use buoyancy here.
gneill
Mentor
20,945
2,886
Buoyancy force acts upwards. Buoyant force magnitude is equal to the weight of the fluid (air in this case) displaced by the object. Whatever force is left over after you've subtracted out the weight of the object is the "lift" -- the lifting force available.
chawki
506
the lift force is like buyancy force (in air)?
gneill
Mentor
20,945
2,886
No, lift is what's left of the buoyancy force once the weight (due to gravity) of the object is subtracted.
chawki
506
The buoyant force = g(mass of the gas + cargo weight)?
gneill
Mentor
20,945
2,886
Well, the "mass of the gas" should include the mass of the balloon's fabric and any other hardware associated with it, but yes that is the idea. When the forces balance as you have written, that is the maximum cargo weight, and the balloon and cargo will just hover.
chawki
506
i really need to understand buoyancy well..the formula that i have writen above..got it when googling about buoyancy..still don't understand it well.and if it is the same in all cases?
all i know so far is that if we contrast water with the case of air..i know that the volume of the ballon equal the volume of air displaced.
where all this will lead us?
chawki
506
(10.5+x)/20 = mair/1.18 ?
gneill
Mentor
20,945
2,886
Hopefully it will lead you to a class or textbook covering the topic! This is probably not the best place to learn a subject from scratch.
To answer your query, yes, buoyancy works in the same fashion for gases and liquids; any time you've got a displaced medium and gravity (or bulk acceleration) working.
gneill
Mentor
20,945
2,886
First calculate the weight of air that is displaced by the balloon.
chawki
506
I think my formula here is wrong
chawki
506
how can we calculate that?
chawki
506
The weight of air that is displaced by the balloon is the same the weight of the ballon.
m*g=1.18*20*9.81=231.51N
gneill
Mentor
20,945
2,886
Okay, make it simple. You have the volume. You have the density of air. What is the mass of air that is displaced?
chawki
506
please check post #18
and sorry for being slow to understand today
gneill
Mentor
20,945
2,886
No problem. Some people think I'm like that all the time (of course, it depends on the topic!).
Okay, so you've determined that displaced air is producing a buoyancy force Fb = 231.51N.
Subtract from that the weight of the balloon and gas inside and you get
Fb - 10.5kg * 9.8m/s^2 = 231.51N - 103.0N = 128.5 N
That is then the net upward force available for lifting cargo.
How much mass can you lift with that force?
chawki
506
why we don't go simply with the basic idea of The volume of balloon = the volume of air displaced
and then...20=(10.5+x)/1.18 and then we find x=13.1kg?
chawki
506
OUPSOUPSOUPS... that's 128.5/9.81=13.1kg too :eek:
chawki
506
Dear gneil
I go to sleep now..i have no idea how i'm thinking or how i think it in post 22
good night, i will continue this tomorrow
gneill
Mentor
20,945
2,886
I went the long way around so that you could see that there are forces involved; The displaced medium (air in this case) results in a buoyant force (in Newtons) when there is a gravitational field involved. You will come across problems involving buoyancy where it is essential that you understand where the forces involved are coming from, and in what directions they act.
chawki
506
is buoyancy related to weight or volume?
in the case of a ship, what would be the condition for floating or sinking?
gneill
Mentor
20,945
2,886
A ship floats because it displaces its own weight in water before it's completely submerged -- it sinks until the weight of water displaced is equal to the weight of the ship. If it didn't displace its own weight in water before it is completely submerged, then its weight would be greater than the maximum possible buoyant force for the ship (the weight of water corresponding to the entire volume of the ship), and it would sink.
chawki
506
Can you please write that mathemaically in equation
chawki
506
Can we use Newton's second law to find Fbuoyancy?
m*g-Fbuoyancy=0
F=m*g
F=density of air*volume of balloon*g
F=1.18*20*9,81
F=231.5N
gneill
Mentor
20,945
2,886
See http://theory.uwinnipeg.ca/physics/fluids/node10.html" [Broken].
  • #31
chawki
506
I am very confused...
WHAT is the general starting point in these situations (i mean floating,lifting)
The volume of the object = the volume of fluid displaced
OR
The weight of the object = the weight of fluid displaced
I mean what is the condition of (floating,lifting) from which we start soving the problem
  • #32
gneill
Mentor
20,945
2,886
OR
Where is the starting point of a circle?
You calculate all the parameters (weights, displaced volume, lift) from the given information and compare them to see what will happen, or determine what is needed in order to make what you want to happen, happen.
Sometimes problems will specify that an object is floating. Sometimes it's sunk. Sometimes it's sinking or rising at a particular rate. Sometimes you're asked to calculate weight, or lift, or density, or determine how far a given object extends into a given fluid when it floats, or how much it protrudes above the surface. Problem writers can be devious in how they provide the information you need in order to solve the problem.
In all cases you need to determine the forces acting and how they depend upon the densities and geometry of the things involved.
  • #33
chawki
506
why it's not 10.5 kg as given
  • #34
gneill
Mentor
20,945
2,886
Because that is the mass of the balloon, not the mass of the air displaced by the balloon.
  • #35
chawki
506
so the weight of the ballon is simply 10.5*9.81=103.005 N ?
Suggested for: Meteorological balloon
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
