• Support PF! Buy your school textbooks, materials and every day products Here!
Method for unit conversion?
  • Thread starter Dave_
I need to convert 12.5 MPa·mm1/2 into MPa.m1/2.
I am unsure on how to do this, my two guesses are as follows:
1. (12.5) / ( 1 / 10001/2) = 395.28 MPa.m1/2
2. (12.5) / (12.5 / 10001/2) = 31.62 MPa.m1/2
Is either of those correct? Thanks!
Answers and Replies
Dear Dave,
is the 1/2 exponent correct? Isn't it -2?
Best regards!
Dear Dave,
Best regards!
I've just doubled checked and the 1/2 exponent is correct, the value is a material constant. Is it possible to convert it into MPa.m1/2? Thanks.
Nathanael
1,650
239
It should be possible.
(MPa = "MegaPascal"?)
(mm = "millimeter"?)
(If those [itex]\uparrow[/itex] are the units then) Your original two answers shouldn't be right, because you would expect the answer to be significantly smaller, right?
(Converting mm to m would decrease the numerical value)
Ahh I see, so should I be calculating (12.5 / 10001/2) = 0.395 MPa.m1/2?
Thanks!
Nathanael
1,650
239
Thanks!
Yeah
The meticulous method of figuring it out would be:
[itex]12.5 MPa(mm)^{1/2}=12.5MPa(\frac{m}{1000})^{1/2}=\frac{12.5MPa\cdot m^{1/2}}{1000^{1/2}}=0.395MPa\cdot m^{1/2}[/itex]
Dear Dave,
this is new to me! What is this unit used for?
Best regards!
Related Threads on Method for unit conversion?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
