Homework Help: Method of Differences
  1. Nov 17, 2008 #1
    I'm given the identity:
    [tex]\sum{\frac{r^{3}-r+1}{r(r+1)} \equiv r-1 + \frac{1}{r} - \frac{1}{r+1}[/tex]
    EDIT: from r=1 to n on the sum sign
    2. Relevant equations
    I know I'm ment to use the method of differences and I know that
    [tex]\sum(r) = \frac{n(n+1)}{2}[/tex]
    3. The attempt at a solution
    I presume you need to find out how you can relate the 3 fractions to the summation of r?
  3. Nov 17, 2008 #2
    tiny-tim
    Hi thomas49th! :smile:
    Hint:
    i] r3 - r = … ?
    ii] with a view to using differences, 1/r(r+1) = … - … ? :wink:
  4. Nov 17, 2008 #3
    sorry to of wasted your time but the orginal question was
    there is no 1/2
    sorry!
    Errr can I combine it to this:
    [tex]\sum (r) - 1 + \sum(\frac{1}{r} - \frac{1}{r+1})[/tex]
    does that help at all?
    [tex]\sum(\frac{1}{r} - \frac{1}{r+1})[/tex]
    simplifies to [tex]\sum(\frac{1}{r^{2} + r}) [/tex]
    Thanks! :)
  5. Nov 17, 2008 #4
    tiny-tim
    So ∑ 1/(r2 + r) = … ? :smile:
    erm … I could see it was wrong! … in fact, I still think it's wrong!! :rolleyes:
    Not following you. :confused:
    The method of difference involves subtracting the answer for r = n from the answer for r = n-1.
  6. Nov 17, 2008 #5
    I could do part a) that's easy just part part b) is giving me trouble.
    At first I tried [tex]\sum (r) - 1 + \frac{1}{\sum (r)} - \frac{1}{\sum (r) + 1}[/tex]
    but that's wrong?
  7. Nov 17, 2008 #6
    tiny-tim
    The ∑n part is right.
    The 1 should be ∑1.
    The rest is just ∑(1/r - 1/r+1) …
    that's already in differences, isn't it? …
    so its sum is … ? :smile:
  8. Nov 17, 2008 #7
    is the sum:
    [tex]\frac{n(n+1)}{2} - n + \frac{2}{n(n+1)} - \frac{2}{n(n+1) + 2n}[/tex]
    is that right?
    is the sum of 1 = n?
  9. Nov 17, 2008 #8
    tiny-tim
    The first two terms are right. :smile:
    As I said before: The rest is just ∑(1/r - 1/r+1)
    Look … that's (1/1 - 1/2) + (1/2 - 1/3) + (1/3 - 1/4) + …
    can you see what's happening?
    this is why it's called the method of differences, and why it works!
  10. Nov 17, 2008 #9
    I know the trick when things cancel out.
    So are you substituting values 1 to n into 1/2 - 1/r+1?
    how was I ment to spot that you substitute values into there and not the first part?
    Thnanks :)
  11. Nov 17, 2008 #10
    tiny-tim
    Exactly! :biggrin:
    Because the first part was easy … it was just ∑(r + 1) …
    but the second part was ∑ 1/r(r+1), which obviously needs a trick! :smile:
  12. Nov 18, 2008 #11
    Ahh yes I got it
    [tex]\frac{n^3 + n}{2(n+1)}[/tex]
    Thank you ever so much :)
Loading...
