I Metric components
  1. Dec 3, 2016 #1
    The component of a one-form W can be represented using the metric as Wβ = gαβUα, where Uα is the component of a vector U, and one can always multiply Wβ by some Vβ to get the inner product between the two vectors U and V.
    My question is: since the inner product is defined with the two components having the same index, like WβVβ, then it would mean that any given component gαβ with α ≠ β would be zero? i.e. every metric is diagonal?
    I suspect it is true at least for familiar coordinate systems, because I noticed either in cartesian coordinates or spherical coordinates any component with two different indices is equal to zero.
  3. Dec 3, 2016 #2
    Ibix
    Counter-example: the Kerr metric, describing spacetime around a rotating black hole, has a ##dtd\phi## term.
  4. Dec 3, 2016 #3
    What about the inner product in that case?
  5. Dec 4, 2016 #4
    Ibix
    What about it? It's ##g_{\mu\nu}U^\mu V^\nu## as with any other metric. It just means that there's some cross-talk between the ##t## and ##\phi## components that gets more significant as you get closer to the hole. So (using the ordering ##t,r,\theta,\phi##) (1,0,0,0) and (0,0,0,1) aren't orthogonal although (1,0,0,0) and (0,0,1,0) are.
  6. Dec 4, 2016 #5
    Where do you get the definion? There is no "two components having the same infex" in the inner product definition.
  7. Dec 4, 2016 #6
    From Nakaraha's book.
    "Take a vector V = Vµ∂/∂xµ and a one-form ω = ωµdxµ. The inner product , < , > : TpM* × Tp M → R is defined
    by <ω, V> = ωµVν <dxµ, ∂/∂ xν> = ωµVνδνµ = ωµVµ.
  8. Dec 4, 2016 #7
    Try to find another book please. My lecturer warned me that I should be careful when I read Nakahara's book, because there are some missconceptions. Apparently you've found one. "Inner product ( , ) between two vectors u and v, is a linear mapping from VxV to F, where V is a vector space and F is a field which satisfies properties 1... 2... 3..."
    If you find such definition, maybe you've found the proper definition of an inner product. It is not even necessary to introduce metric in the first place, but we can make a special inner product using metric.
  9. Dec 4, 2016 #8
    Ibix
    @kent davidge - I'm not sure if this will help.
    In coordinates where the metric is diagonal the one-form created by lowering an index on a vector will have each component depending only on the corresponding component of the vector - that is ##W_t\propto V^t## etc. In coordinates where the metric is not diagonal at least one of the components of ##W## will depend on more than one component of ##V## - for example ##W_t=g_{tt}V^t+g_{t\phi}V^\phi## in the Kerr metric, where no implicit summation over indices is intended. That's how the non-diagonal nature of the metric comes out in the ##W_\mu V^\mu## version of the inner product.
  10. Dec 4, 2016 #9
    Oh ok. What books are you using in your course?
    I realized that there's no need of having equal indices. Thanks.
  11. Dec 4, 2016 #10
    For inner product definition, its on Functional Analysis class. Unfortunately, I forgot the author, nut the title is Applied Functional Analysis (GTM 108). But for simplicity, you can find the definition at wikipedia. The point is, the inner product definition doesn't need any summation over indices.
  12. Dec 5, 2016 #11
    Ben Niehoff
    Not every metric is diagonalizable in a coordinate basis. One can show (using rather fancy methods in some cases!) that:
    In 2 dimensions, one can always find coordinates such that the metric takes the form
    $$\begin{pmatrix}g_{11} & 0 \\ 0 & g_{22} \end{pmatrix}.$$
    In 3 dimensions, one can always find coordinates such that the metric takes the form
    $$\begin{pmatrix}g_{11} & 0 & 0 \\ 0 & g_{22} & 0 \\ 0 & 0 & g_{33} \end{pmatrix}.$$
    However, in 4 dimensions, the best one can do is the following: One can always find coordinates in which the metric takes the form
    $$\begin{pmatrix} g_{11} & g_{12} & 0 & 0 \\ g_{12} & g_{22} & 0 & 0 \\ 0 & 0 & g_{33} & g_{34} \\ 0 & 0 & g_{34} & g_{44} \end{pmatrix}.$$
    In higher dimensions, I'm not sure what you get. But generally, in ##d## dimensions you have ##d(d+1)/2## algebraically independent components (since the metric is symmetric), and ##d## gauge symmetries (from coordinate transformations), so it is possible to reduce the metric to a form with only ##d(d-1)/2## non-zero entries. The trick is figuring out exactly which terms have to be non-zero.
    Note also that this is not usually the most convenient form of the metric to use, and the coordinate transformations that get you there might be extremely complicated.
  13. Dec 5, 2016 #12
    I see. Thanks.
    Thanks bro
  14. Dec 6, 2016 #13
    stevendaryl
    Staff Emeritus
    That's very interesting. You can always diagonalize the metric at a single point, right? So what you're saying is that you can always find a coordinate system so that it is in that "almost-diagonal" form everywhere within a coordinate patch?
  15. Dec 6, 2016 #14
    Ben Niehoff
    You need to be clear what you mean by "diagonalize". The metric is an invertible symmetric matrix, so it can always be diagonalized algebraically; in fact, it can be brough to a standard form where the diagonal entries are ##\pm 1##. But the resulting basis will not, in general, be a coordinate basis.
    What I've discussed in my post above is a more restrictive question: Can I diagonalize the metric by coordinate transformations? Then the resulting basis is still a coordinate basis. Obviously for dimensions greater than 3, this cannot be done, because the metric has a greater number of degrees of freedom than it has diagonal entries. The surprising part is that in dimensions 3 or less, the answer is yes.
    Then, a related question is, in dimensions 4 and higher: I know I cannot diagonalize the metric by coordinate transformations, but can I put it in a standard form? The answer is yes, although I don't know if the standard forms have been worked out in dimensions higher than 4.
    All of this is true in an open neighborhood (i.e. coordinate patch), not just at a point.
  16. Dec 6, 2016 #15
    stevendaryl
    Staff Emeritus
    I was talking about coordinate transformations, too. Can't you always find a coordinate system so that the metric in that coordinate basis is diagonal at a single chosen point?
  17. Dec 6, 2016 #16
    Ben Niehoff
    Yes, of course. You can even make the diagonal entries all ##\pm 1##. These are the Riemann normal coordinates.
    But I'm talking about things that hold in a finite patch.
Have something to add?
Draft saved Draft deleted
