Metric for a surface of a cone
In summary, the conversation discussed the metric for a surface and the Euler-Lagrange equation for finding the value of phi. It was shown that phi can be solved to equal k divided by omega squared times r squared. This value can then be substituted back into the metric to find the value of r.
gboff21
50
The metric for this surface is [itex]ds^2 = dr^2 + r^2\omega^2d\phi^2[/itex], where [itex]\omega = sin(\theta_0)[/itex].
Solve the Euler-Lagrange equation for phi to show that [itex]\dot{\phi} = \frac{k}{\omega^2r^2}[/itex]. Then sub back into the metric to get [itex]\dot{r}[/itex]
[itex]L = 1/2 g_{ab} \dot{x}^a \dot{x}^b[/itex]
I've solved it to get [itex]\ddot{\phi} + 2\frac{\dot{r}}{r}\dot{\phi} = 0 [/itex]
and
[itex]\ddot{r} - r\omega^2\dot{\phi}^2 = 0[/itex]
So how on Earth do you get that answer?
Note how you got this equation. Back up a step where you must have had ##\frac{d}{dt} (\rm { expression}) = 0##
What can you conclude about the expression?
Likes 1 person
Ok I get it! [itex] d/dt (\dot{\phi} r^2 \omega^2)=0[/itex]. So [itex]\dot{\phi} = k/(r^2\omega^2)[/itex]
Thanks!
That's it. Good!
I would first clarify what the problem is asking for. Is it asking for the metric of the surface of a cone or is it asking to solve the Euler-Lagrange equation for phi? These are two separate tasks and it is important to have a clear understanding of what is being asked in order to provide an accurate response.
Assuming the problem is asking for the metric of the surface of a cone, the given metric ds^2 = dr^2 + r^2\omega^2d\phi^2 is correct. This metric represents the infinitesimal distance on the surface of a cone in terms of the coordinates r and phi. The parameter \omega is a constant that depends on the angle \theta_0, which is the angle between the cone's axis and its generating line.
If the problem is asking to solve the Euler-Lagrange equation for phi, then the given solution is also correct. The Euler-Lagrange equation is used to find the equations of motion for a system described by a Lagrangian, which is given by L = 1/2 g_{ab} \dot{x}^a \dot{x}^b. In this case, the Lagrangian is the metric ds^2 and the equations of motion are \ddot{\phi} + 2\frac{\dot{r}}{r}\dot{\phi} = 0 and \ddot{r} - r\omega^2\dot{\phi}^2 = 0. Solving these equations gives the solution \dot{\phi} = \frac{k}{\omega^2r^2}, where k is a constant, and \dot{r} can be obtained by substituting this solution back into the second equation.
In conclusion, the given metric for the surface of a cone is correct and the solution for the Euler-Lagrange equation for phi is also correct. However, it is important to have a clear understanding of what is being asked in order to provide a relevant response.
1. What is the formula for finding the surface area of a cone?
The formula for finding the surface area of a cone is SA = πr² + πr√(r² + h²), where r is the radius of the base and h is the height of the cone.
2. How do you calculate the lateral surface area of a cone?
The lateral surface area of a cone can be calculated using the formula LA = πrl, where r is the radius of the base and l is the slant height of the cone.
3. Can the surface area of a cone be negative?
No, the surface area of a cone cannot be negative. It is a physical quantity that represents the total area of the curved surface of the cone, and therefore cannot have a negative value.
4. How does the surface area of a cone change as the height decreases?
The surface area of a cone decreases as the height decreases. This is because the surface area is directly proportional to the height of the cone, and as the height decreases, the curved surface gets smaller.
5. Is there a difference between the surface area of a right cone and an oblique cone?
Yes, there is a difference between the surface area of a right cone and an oblique cone. While the formula for finding the surface area is the same, the slant height l is different for a right cone (equal to the height h) and an oblique cone (greater than the height h). This results in a larger surface area for an oblique cone compared to a right cone with the same base and height.
