Homework Help: Metric Space/Open Ball
  1. Sep 3, 2011 #1
    Hi guys, two problems, first one I understand for the most part, the second one, I do not know how to set up and solve.
    Let X = R[itex]^{n}[/itex] for x = (a[itex]_{1}[/itex],...,a[itex]_{n}[/itex]) and y = (b[itex]_{1}[/itex],...,b[itex]_{n}[/itex]), define
    d[itex]_{\infty}[/itex](x,y) = max {|a[itex]_{1}[/itex]-b[itex]_{1}[/itex]|,...,|a[itex]_{n}[/itex]-b[itex]_{n}[/itex]|}. Prove that this is a metric.
    2. Relevant equations
    Just the triangle inequality part for this one.
    3. The attempt at a solution
    I've proven the first 3 properties, not quite sure on the last part.
    My attempt was to break it up into n cases by supposing a single
    difference as the max in each case but with ellipsis but I wasn't
    sure on the exactly how. Here's what I attempted:
    The distance between the two points is the largest of the n cases.
    Let z = (z[itex]_{1}[/itex],...,z[itex]_{n}[/itex]). Then we have n cases to check.
    Case 1: d(x,y) = |a[itex]_{1}[/itex]-b[itex]_{1}[/itex]|
    Notice that |a[itex]_{1}[/itex]-z[itex]_{1}|[/itex]|[itex]\leq[/itex]max{|a[itex]_{1}[/itex]-z[itex]_{1}[/itex]|,
    (I stopped here because I wasn't sure how to proceed,
    should I write out to n cases with the ellipsis or two cases?)
    What I was going to show after this was that the triangle inequality
    holds for a[itex]_{1}[/itex], a[itex]_{2}[/itex], ..., a[itex]_{n}[/itex].
    Prove that the set S = {(x[itex]_{1}[/itex],y[itex]_{1}[/itex] : x[itex]_{1}[/itex] + y[itex]_{1}[/itex] > 0}
    is an open subset of R[itex]^{2}[/itex] in the Euclidean metric.
    Euclidean metric, Schwarz Inequality?, Open Ball.
    I'm not sure how to proceed with this one at all. Picture-wise,
    it'd be the region above the y=-x line, I'm guessing,
    and I'm guessing I have to pick some arbitrary point in that
    region and calculate a strict inequality to show that this is open.
    But I do not know how to proceed at all, I'm looking for some hand-holding
    at this point really because I want to understand it step by step.
    Thanks for any help!
  3. Sep 3, 2011 #2
    Let's prove this one like this. Can you first show that
    [tex]|a_k-b_k|\leq \max \{|a_1-z_1|,...,|a_n-z_n|\}+\max \{|z_1-b_1|,...,|z_n-b_n|\}[/tex]
    OK, what does open mean for you?? You need to show for al (x,y) in the set that there exists a ball around(x,y) that stays in the set. How would you choose that ball??
    Does it makes sense what I'm saying?
  4. Sep 3, 2011 #3
    [itex]|a_k-z_k+z_k-b_k|[/itex][itex]\leq |a_k-z_k|+|z_k-b_k|\leq[/itex] max[itex]{|a_1-z_1|,...,|a_n-z_n|}[/itex]+max{|[itex]z_1-b_1|,...,|z_n-b_n[/itex]|}?
    I guess for me right now, open for is something without its boundary points. I would have to pick an r such that for some [itex](x_2, y_2), (x_1, y_1) then (x_2-x_1)^{2} + (y_2-y_1)^{2} \leq r^{2}[/itex]?
  5. Sep 3, 2011 #4
    OK, and now that the maximum of the left-hand side.
    What is your definition of open? Saying that it's something without boundary isn't good enough unless you specify what a boundary point is.
  6. Sep 3, 2011 #5
    The max's are the distances, gotcha, thanks.
    In this problem, I'd say the boundary is the y = -x line.
  7. Sep 3, 2011 #6
    Yes, but what is the definition of a boundary??
  8. Sep 3, 2011 #7
    Set of points that encloses a space, endpoints? I don't know what you mean.
  9. Sep 3, 2011 #8
    Please, look up in your course the definition of "open set" and such things. We can't really do much unless we have some definitions to work with...
  10. Sep 3, 2011 #9
    It's just the open ball centered at x
    B(x,r) = { y in X: d(x,y) strictly less than r}
  11. Sep 3, 2011 #10
    What is just the open ball??
    Could you please quote the exact definition of an open set?? Yes, it has something to do with open balls.
  12. Sep 3, 2011 #11
    Just quoting the definition from my notes:
    Given a metric space (X,d) a subset S[itex]\subseteq[/itex]X is called open provided that whenever x[itex]\epsilon[/itex]S, then there is an r>0 such that B(x;r)[itex]\subseteq[/itex]S.
  13. Sep 3, 2011 #12
    Exactly!!
    So for our [itex]S=\{(x,y)~\vert~x+y>0\}[/itex], we need to find for each [itex](x,y)\in S[/itex], a r such that [itex]B(x,r)\subseteq S[/itex].
    So, let's pick an arbitrary (x,y) in S. What do you think we should take as our r?
  14. Sep 3, 2011 #13
    By the way, did you see the open set characterization of continuity yet?? That might come in very handy!!
  15. Sep 3, 2011 #14
    Something greater than 0 but less than x+y? I don't know how we go about picking the r.
    I'm just starting out in real analysis, haven't come across it yet, we've only gotten past closed sets which was a bit easier to digest.
  16. Sep 3, 2011 #15
    OK, take an arbitrary point in S. What is the distance between that point and the line y=-x??
  17. Sep 3, 2011 #16
    [itex]\sqrt{(y_{o}-y)^{2}+(x_{0}-x})^2[/itex], since y=-x, do I make that substitution into the formula?
  18. Sep 3, 2011 #17
    What is [itex](x_0,y_0)[/itex] and (x,y)??
  19. Sep 3, 2011 #18
    (x,y),(xo,yo) in S
  20. Sep 3, 2011 #19
    But why would you do that?? Why would you pick both of them in S??
    I want to find the least distance between a point (x,y) in S and the line y=-x. This is just a calculus/geometry question... How would you solve that??
  21. Sep 3, 2011 #20
    I was thinking we had to use the eclidean distance formula for some reason. |x+y|/sqrt(2)
  22. Sep 3, 2011 #21
    Indeed, the distance between a point [itex](x,y)\in S[/itex] and the line y=-x is exactly
    [tex]\frac{|x+y|}{\sqrt{2}}[/tex]
    Now, if we choose
    [tex]r=\frac{|x+y|}{\sqrt{2}}[/tex]
    isn't it true that the ball B((x,y),r) stays inside of S?
  23. Sep 4, 2011 #22
    Sorry for the departure.
    Yes, because 0<[itex]\frac{|x+y|}{\sqrt{2}}[/itex]<y1+y2. Thus B((x,y),r)[itex]\subseteq[/itex]S proving the set is an open subset in R[itex]^{2}[/itex].
    I see. So when the question asks take the Euclidean metric, I shouldn't use the euclidean metric we learned in class but just find the distance from previous knowledge?
    So if I had to prove the set S={(y1,y2): y1>0} is an open subset of R[itex]^{2}[/itex].
    Then all I'd have to do is let (x,y)[itex]\epsilon[/itex]S and pick r = |x|, then B((x,y),r)[itex]\subseteq[/itex]S making it an open subset?
  24. Sep 4, 2011 #23
    You did use the Euclidean metric here. To find out the distance between the line and the poitn, you actually needed to use the Euclidean metric/
    The radius depends on the open set in question. Right now [itex]|x+y|/\sqrt{2}[/itex] works, but such a trick doesn't always work...
  25. Sep 4, 2011 #24
    Did I mess up the second one then?
    I have a question on notation. My professor uses d[itex]_{\infty}[/itex](x,y) = max{|stuff|, ...}. So when the question says prove that the disk x[itex]^{2}[/itex]+y[itex]^{2}[/itex]<1 is an open subset of (R[itex]^{2}[/itex],d[itex]_{\infty}[/itex]), what does (R[itex]^{2}[/itex],d[itex]_{\infty}[/itex]) mean?
Loading...
