mtworkowski@o
- 213
I think I read somewhere that there's a flaw in the Michaelson Morley experiment. Is this true?
russ_watters said:The Michelson Morley experiment is over a hundred years old. It has quite a few flaws! And it has, of course, been refined considerably since then. But at the time that it was done, it was done correctly and as well as could be expected and provided groundbreaking evidence of the constancy of the speed of light and lack of existence of an aether.
Nickelodeon said:Did they test for an aether traveling vertically or just horizontally?
I'm not sure that example works because cars are designed to be crushed while bridge abutments are not. How about this: a head-on collision between two cars going at 60mph is the same energywise as a collision between a car moving at 120mph and a stationary car. In any case, yes, kinetic energy is relative to the reference frame. I'm not sure what that has to do with the speed of light, though.mtworkowski@o said:when I think of IR frames, the one thing I think of is this. Is the speed of light dependent on the speed of the source. Here's the thought. Tell me if this is amusing. "Which is the worst of the collisions? A: 2 cars head on at 60 mph each. (both same mass). B: 1 car, 60 mph hits a bridge abutment.
That's a very common misconception about the MM experiment, and I can never understand why: If you read any halfway decent description, of it, the usual analogy is to compare the MM experiment to measuring the speed of a boat moving sideways across a river -- not up and down the river.Oh and can I just add this? Somebody told me that because the MME used light going in two directions that it averages out the delta v. What do you all think?
Yes, the speed of light is independent of both the speed of the source and the speed of the "observer". That's the whole point of the Michaelson-Morley experiment (and its many refinements).mtworkowski@o said:when I think of IR frames, the one thing I think of is this. Is the speed of light dependent on the speed of the source.
If two cars, each going 60 mph, hit head on, that is equivalent to a car hitting a parked car at (approximately) 120 mph. While it's not quite equivalent to hitting a bridge abutment (which isn't going to "give") at 120 mph, I think it would be much worse than hitting an abutment at only 60 mph.Here's the thought. Tell me if this is amusing. "Which is the worst of the collisions? A: 2 cars head on at 60 mph each. (both same mass). B: 1 car, 60 mph hits a bridge abutment.
Yes, the only way to measure the "speed of light" in two different directions (at right angles to one another) at the same time and same place was to use light that goes "out and back". In his original paper on Special Relativity, Einstein clearly stated that he was only assuming that average speed of light "here to there and back to here" was the same in all reference frames.Oh and can I just add this? Somebody told me that because the MME used light going in two directions that it averages out the delta v. What do you all think?
HallsofIvy said:Yes, the speed of light is independent of both the speed of the source and the speed of the "observer". That's the whole point of the Michaelson-Morley experiment (and its many refinements).
The negative acceleration in the case of the two cars is exactly the same as that of the one car. A high speed photo will show that the center of impact does not move in either case. 60 mph to 0 takes the same time in both cases.
Now for the model with the light. The way we're measuring time is arrival time. We don't have to vary the speed and direction of the source if we can do the same for ourselves. We're sailing along in space and hit the wave front of an arriving light. At the same instant and location our stationary twin is just receiving the same wave front. We pass out twin at exactly the instant that the wave front reaches our measuring equipment. Two reference frames; one for us and one for our twin. The light reaches us at the same time.
Where have I gone wrong? That is light being measured at the same speed in two different IR frames.
cristo said:What, you mean into the earth?
mtworkowski@o said:I'll draw the analogy the way I see it and you can clear it up. wind is west to east at 50 mph. Plane is traveling at 150 air speed west to destination and then back. Ground speed out is 200 and back is 100. Average is what? That's the problem these people are seeing.
russ_watters said:How about this: a head-on collision between two cars going at 60mph is the same energywise as a collision between a car moving at 120mph and a stationary car.
Nickelodeon said:Yes - if you wanted to test for an aether then it would be worth checking that direction too.
Nickelodeon said:I don't think they were expecting the average speed of light in the respective directions to be different. I imagine they were hoping to see a wavelength variation. With your plane analogy above, the interference pattern would be apparent. I think that is the general idea.
mtworkowski@o said:You know, this still sounds fishy.
paw said:Think of it this way. If one arm of the interferometer were parallel to the ether the effective path length would be 2L. But then the other arm would be orthoganal to the ether and the effective path length would be >2L. How much greater would depend on the Earths velocity through the ether but it would be greater.
It's this difference in path length that would cause the interferance pattern in the detector. Ultimately there were no interferance patterns and no ether detected.
paw said:Why? Just wait 6hrs and the Earth plus apparatus will rotate 90 degrees.
Furthermore the Earth couldn't be moving through the ether in two orthoganal directions at the same time so the two arms of the interferometer are enough to detect an ether if it was there. A third arm is completely unnecessary.
mtworkowski@o said:I think I read somewhere that there's a flaw in the Michaelson Morley experiment. Is this true?
mtworkowski@o said:when I think of IR frames, the one thing I think of is this. Is the speed of light dependent on the speed of the source. Here's the thought. Tell me if this is amusing. "Which is the worst of the collisions? A: 2 cars head on at 60 mph each. (both same mass). B: 1 car, 60 mph hits a bridge abutment. Oh and can I just add this? Somebody told me that because the MME used light going in two directions that it averages out the delta v. What do you all think?
Again, you have it wrong. In this airplane analogy, if the plane is traveling east-west, the wind must be traveling north-south. You'll never understand why the MM exp works if you can't comprehend why traveling perpendicular to the ether takes longer the faster the ether is moving.mtworkowski@o said:I'll draw the analogy the way I see it and you can clear it up. wind is west to east at 50 mph. Plane is traveling at 150 air speed west to destination and then back. Ground speed out is 200 and back is 100. Average is what? That's the problem these people are seeing.
When two cars collide at the same speed or when one car hits a bridge, the final energy of the system is zero (everything is stationary after the collision) and all of the kinetic energy went into crushing the carBorek said:And not stationary plus one moving at about 85 mph? Or have I misunderstood "energywise"?
russ_watters said:When two cars collide at the same speed or when one car hits a bridge, the final energy of the system is zero (everything is stationary after the collision) and all of the kinetic energy went into crushing the car. When a moving car hits a parked car, both cars are moving after the collision, and there is a remaining kinetic energy that has to be subtracted from the collision.
Nickelodeon said:If there is an aether then the Earth isn't moving through it, as shown by the MM experiments. However, it would be worth checking that the aether isn't traveling towards the Earth's centre. You would need to put one of the mirrors at the top of a cliff and the other mirror an equal distance but horizontal. The time the light takes to complete the two paths should be the same but the wavelength of the merging beams should be different.
ZapperZ said:This is a fishing expedition.
"We require that when someone says "I read somewhere" or "I heard somewhere", that the exact valid references is given. Or else, it is impossible to know if what you read is correct or valid, if you interpreted it correctly, or if you are reading some crackpot information. So from now on, please provide the exact source if you wish to understand if what you read or heard is correct.
Zz said:"However, please note that, per the https://www.physicsforums.com/showthread.php?t=5374", dubious sources are not allowed to be referenced here."
Zz said:"I think you need to double check if you have understood relativistic velocity addition, because simply using Galilean velocity addition to negates the MM experiment just doesn't work."
Fredrik said:Consider that last scenario (a car hitting a parked car at 120 mph) viewed from a frame that's moving at 60 mph relative to the ground. It's going to look exactly the same as a collision between two cars both doing 60 mph in the frame where the ground is stationary (neglecting friction).
MikeLizzi said:I see a lot of confusion here. At the risk of adding more, allow me to suggest this discussion I have posted on my web site.
http://mysite.verizon.net/mikelizzi/MichaelsonMorelyAnalogy.htm
russ_watters said:Again, you have it wrong. In this airplane analogy, if the plane is traveling east-west, the wind must be traveling north-south. You'll never understand why the MM exp works if you can't comprehend why traveling perpendicular to the ether takes longer the faster the ether is moving.
Btw, when applied to a plane or a boat, this is called crabbing: http://en.wikipedia.org/wiki/Crab_landing
PhilDSP said:Just curious: has anyone performed a related experiment where both group velocity and phase velocity were recorded at the same time?
