How Does a Michelson Interferometer Measure the Thickness of a Piece of Plastic?
In summary, the experiment with the Michelson interferometer aims to measure the thickness of a piece of plastic using white light. The central fringe in the interference pattern is used as a reference because it corresponds to equal path lengths in both beams and is the only high contrast fringe with white light. By adjusting the arms of the interferometer, the distance can be measured and the thickness of the plastic can be calculated.
whatisreality
290
I'm reading about an experiment done with a Michelson interferometer. The aim is to measure the thickness of a piece of plastic. They use white light, so the central fringe in the interference pattern, corresponding to equal path lengths in the two beams can be used as a reference. Why does that work? I'd really appreciate an explanation (as simple as possible) as to why they do this.
The central fringe corresponds to both beams having traveled equal distances... The displacement of one fringe has to be tracked when the plastic is placed. That's about as much as I understand. Why is the central fringe a reference? If it's the only one that doesn't move, why is that?
Thanks for any help!
White light (WL) has a very short coherence length - so with WL interferometer you basically can get only one high contrast fringe (black/white). Other fringes will be in lower contrast, blurred and with rainbow-like features.
As you get only one high contrast fringe it is trivial to use it as a reference.
Most simple setup would be like this: adjust interferometer without the plastic sample in such a way that the highest contrast fringe is visible in the center. Then add sample and change interferometers arms length until you will see highest contrast fringe in the center again. The distance in arms length - is double times the optical distance of your sample.
1. What is a Michelson interferometer?
A Michelson interferometer is a scientific instrument used to measure minute changes in the length of an object or the wavelength of light. It consists of a beam splitter, two mirrors, and a detector, and uses the principles of interference to measure small displacements or wavelength shifts.
2. How does a Michelson interferometer work?
A Michelson interferometer works by splitting a beam of light into two paths using a beam splitter. One of the paths reflects off of a fixed mirror, while the other reflects off of a movable mirror. These two beams are then recombined, and any changes in the length of the movable path or the wavelength of the light will result in interference patterns that can be measured by a detector.
3. What are the applications of a Michelson interferometer?
A Michelson interferometer has many applications in science and technology. It is commonly used in precision measurements, such as measuring the speed of light, the refractive index of materials, and the wavelength of light. It is also used in spectroscopy to analyze the composition of materials and in interferometric microscopy to study the structures of small objects.
4. Are there any limitations to using a Michelson interferometer?
While a Michelson interferometer is a powerful tool, it does have some limitations. It is most accurate when measuring small displacements or wavelength shifts, so it may not be suitable for measuring large changes. Additionally, environmental factors such as vibrations or temperature changes can affect the accuracy of the measurements.
5. How does a Michelson interferometer differ from other interferometers?
A Michelson interferometer differs from other interferometers in its design and the way it measures displacements or wavelength shifts. It uses a beam splitter to split the beam of light, while other interferometers may use different methods such as diffraction gratings. Additionally, a Michelson interferometer can measure both displacements and wavelength shifts, while other interferometers may only measure one or the other.
  • Other Physics Topics
  • Optics
  • Classical Physics
  • Classical Physics
