Constructing an Electromagnetically Actuated Micro Pump
  • Thread starter Karate Chop
  • Tags
    Micro Pump
In summary, the conversation discusses constructing an electromagnetically actuated micro pump and asks for ideas and information about its application, function, and specifications. Suggestions include looking into existing manufacturers and technologies, such as those used in ink jet printers and aerospace and hydraulic applications, and considering factors like fluid type, distance, and pressure.
Karate Chop
Does anyone have any ideas on how to construct an electromagnetically actuated micro pump? If so, please post.
What is the application and what you want to accomplish? With a bit description, you may come to know that you need not reinvent a wheel.
What do you mean by "actuated?" Do you mean electromechanically driven? Also, what kind of pressure or flow range do you consider micro?
Again, more information is needed. If 'micro' means something like for a table-top fountain, your best bet would probably be like a little artificial heart, with 2 oppositely oriented check valves and an oscillating membrane like a speaker cone. If you mean something surgically implanted in an artery or some such, you pretty much have to get into nanotech devices. If you mean something along the line of magnetohydrodynamics, then you would need someone like Astronuc to get in on this. A very big deciding factor will be what kind of fluid you intend to pump, for what distance, and at what pressure. Something highly viscous like hydraulic oil or liquid polymers won't work with a set-up that would be fine for water.
A lot of MFG make them I sure,some are used in things like ink jet printers check out
http://www.leeproducts.co.uk/news.htm
I just ran across this yesterday, I am sure there are a lot of places.
Lee is a good company to look at but they are pricey. They are used a lot in aerospace and hydraulic apps. Not quite off the shelf, but perhaps you might be able to convince them to send you a sample.
1. What is an electromagnetically actuated micro pump?
An electromagnetically actuated micro pump is a small device that uses electromagnetic forces to move fluids or gases. It typically consists of a coil, a magnet, and a diaphragm or piston that is moved by the electromagnetic forces to create a pumping action.
2. How does an electromagnetically actuated micro pump work?
The pump works by applying an alternating current to the coil, which creates a changing magnetic field that interacts with the permanent magnet. This causes the diaphragm or piston to move, creating a pressure difference that pumps the fluid or gas through the pump.
3. What are the advantages of using an electromagnetically actuated micro pump?
One advantage is its small size, making it suitable for use in microfluidic systems. It also has no moving parts, reducing the risk of mechanical failure. Additionally, the pumping action can be easily controlled by adjusting the frequency and amplitude of the current.
4. What are the potential applications of an electromagnetically actuated micro pump?
These pumps have a wide range of potential applications, including drug delivery systems, lab-on-a-chip devices, and microfluidic cooling systems for electronics. They can also be used in medical devices, such as insulin pumps and drug infusion pumps.
5. Are there any limitations or challenges in constructing an electromagnetically actuated micro pump?
One challenge is achieving precise control over the pumping action, as small changes in the current can lead to significant changes in the flow rate. Another limitation is the need for a power source to generate the alternating current, which can be difficult to integrate into small devices.
  • General Engineering
9K
