NeoDevin
- 334
- 2
Does anyone here know if it's possible to connect my Canon S100 (with a mini USB port) to my Nexus 7 tablet (with a micro USB port), to copy the pictures over?
The purpose of connecting a Mini USB to Micro USB is to transfer data and charge the devices. The Canon S100 and Nexus 7 both have different USB ports, so a cable with a Mini USB on one end and a Micro USB on the other is needed to connect the two devices.
No, it is important to use a cable that is compatible with both the Canon S100 and Nexus 7. Some cables may only work for charging and not data transfer, or may not fit properly in the device ports. It is best to use a cable that is specifically designed for both devices.
You can test if your cable is working by connecting the Canon S100 and Nexus 7 together and attempting to transfer data or charge the devices. If the devices recognize each other and the data transfer or charging is successful, then the cable is working properly.
Yes, the Mini USB to Micro USB cable can be used to transfer photos from the Canon S100 to the Nexus 7. Simply connect the two devices together and follow the prompts on the Nexus 7 to import the photos from the Canon S100.
It is generally safe to leave the devices connected for extended periods of time, as long as they are both fully charged and the cable is in good condition. However, it is always recommended to disconnect the devices when not in use to avoid any potential damage to the ports or cables.
