• Support PF! Buy your school textbooks, materials and every day products Here!
Minimizing Surface Area
  • Thread starter Sheneron
[SOLVED] Minimizing Surface Area
1. Homework Statement
A can is to be manufactured in the shape of a circular cylinder with volume = 50.
Find the dimensions of a can that would minimize the amount of material needed to make the can.
2. Homework Equations
V = [tex] \pi r^2 h[/tex]
SA = [tex] 2 \pi r^2 + 2 \pi r h [/tex]
3. The Attempt at a Solution
I have never done a problem like this so I am unsure how to do it, but here is my attempt.
With the volume equation I solved for h. [tex] h = \frac{50}{\pi r^2} [/tex]
I plugged this value for h into the Surface area equation. [tex] SA = 2 \pi r^2 + 2 \pi r \frac{50}{\pi r^2} [/tex]
which = [tex] 2 \pi r^2 + \frac{100}{r} [/tex]
I then took the derivative of that and set it equal to 0.
[tex] 0 = 4 \pi r - 100 r^-2 [/tex]
[tex] r = \sqrt[3]{\frac{100}{4 \pi}} [/tex]
r = 1.996
Then I plugged that back into the volume equation to solve for h and got h= 3.99.
Could someone tell if this is right and if not where I went wrong. Thanks.
Answers and Replies
Looks good to me. Check your result by plugging in a number smaller than r and a number bigger than r into the derivative. If a number smaller than r makes the derivative negative and a number larger than r makes the derivative positive, then r would be a minimum.
So is that how I know that its a minimum instead of a maximum. I'm still a little confused about that. What would I do if I wanted to solve this problem for a maximum?
HallsofIvy
41,738
899
There is no maximum.
Does it not have one? Even though the volume is set to 50 there is no max Surface area?
If you keep increasing r, the surface area just gets bigger and bigger without bound. The height gets smaller, but there is a separate [tex]2\pi r^2[/tex] term in the surface area calculation. That's why there is no maximum surface area.
I understand I think. h could get infinitely small which would make the surface area infinitely large.
Related Threads for: Minimizing Surface Area
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
