Homework Help: Minimum distance
  1. Dec 22, 2007 #1
    A rectangular room measures 30 feet in length and 12 feet in height, and the ends are 12 feet in width. A fly rests at a point one foot down from the ceiling at the middle of one end and wants to get to a point one foot up from the floor at the middle of other end. Can it get there by walking less than 40 feet.
    2. Relevant equations
    3. The attempt at a solution
    I get that it needs sqrt(1658) > sqrt(1600) feet to get there. What do other people get?
  3. Dec 22, 2007 #2
    Shooting Star
    Could you please show the method?
  4. Dec 22, 2007 #3
    Basically I unfolded the room and found a straight line along the walls from the starting point to the destination. I get that the bug walks along four different walls on this shortest path. Is it wrong?
  5. Dec 22, 2007 #4
    Dick
    Pretend the room is a cardboard box and think of various ways to cut it up so it lies flat and you can draw a straight line between the two points. The shortest one I can find is sqrt(1658) as well.
  6. Dec 22, 2007 #5
    Shooting Star
    I get that the bug walks along three surfaces, the one where it is, the one where it ends up, and the wall in between these two. But I get sqrt(42^2+10^2), which is even higher.
    Tell me about your four walls.
  7. Dec 22, 2007 #6
    Dick
    There's a shorter path crossing four surfaces. Angle up to the ceiling, go along the ceiling for a while, cross on to the side wall and then move on to the end wall. Get those scissors out.
  8. Dec 22, 2007 #7
    Shooting Star
    As far as I can tell, the answer to the original question is no. But I'm waiting for a better solution.
    Incited :mad: by Dick's snippy post (well, he was talking about scissors :wink:), I have destroyed a few rooms and ultimately found the shortest path as 40 ft. This comes from sqrt[(1+30+1)^2 + (12+12)^2] = 40. I'm sure you guys can visualize the way I've opened up the room, without giving any thought to the fact I'm scared of shooting stars falling from the sky.
    What about < 40 ft?
  9. Dec 22, 2007 #8
    Dick
    Oooops. The way I was thinking was sort of ceiling obsessive. Go to a side wall, traverse the wall, then back through the end wall. sqrt(10^2+36^2). It IS less than 40! Thanks for pushing me into rethinking this. I'm still not sure I see the 40 route.
  10. Dec 22, 2007 #9
    Gib Z
    Alternative solution;
    Yes, by flying there instead =D
  11. Dec 23, 2007 #10
    Hmmmm the only way I see is by flying. The shortest path I get is 42 exactly.
  12. Dec 23, 2007 #11
    Dick
    Read the question. The fly has to walk. If it can fly the shortest distance is sqrt(10^2+30^2). Which is definitely not 42.
  13. Dec 23, 2007 #12
    I read it. It doesn't say the fly has to walk. And I dont see how you can get sqrt(10^2+30^2).
  14. Dec 23, 2007 #13
    Gib Z
    I was actually joking when I last posted in this thread >.< Even if it didn't explicitly state, I assumed it had to walk :(
  15. Dec 23, 2007 #14
    Well Gib, I don't see why they would bother making it a fly instead of.. say... a spider. Seems like they are inviting ambiguity. Or.. maybe they did it on purpose and flying is the correct answer.
  16. Dec 23, 2007 #15
    Far as I can see.. there are four paths the fly could take (if walking): If it crosses the ceiling or floor, the distance is 1+30+11=42. If it crosses one of the two side walls, the distance is sqrt(42^2 + 10^2) which is even longer.
  17. Dec 23, 2007 #16
    Shooting Star
    I'm very bad at making picture files, and I don't have a scanner, so I can't show you the path right now. I'll try -- maybe ask someone to make a bmp or whatever file.
    But could you show us your path? Or describe in detail?
  18. Dec 23, 2007 #17
    you nearly got it! you should have gone a little further.
    you should unfold to two dimension in such a way that you draw the small sidewalls up-left and down-right, and (from up to down) the ceiling, one big sidewall and the ground in the middle.
    Now draw a straight line. it's 40 ft.
    You could also try take 6 walls, but as you can see that would only be longer. I think 40 ft. is the minimum.
  19. Dec 23, 2007 #18
    oh wait someone said this already >_> never mind then
  20. Dec 23, 2007 #19
    Shooting Star
    The 40 ft route may be possible to see even without the diagram because of the way I've written it: sqrt[(1+30+1)^2 + (12+12)^2].
    But where are you gettting the 10 from? Please confirm once more.
  21. Dec 23, 2007 #20
    In the book where I found the problem (problem solving through problems) the fly has a broken wing and does explicitly have to walk. I should have written that.
  22. Dec 23, 2007 #21
    I see it now. Its really sqrt[(1+30+1)^2 + (6+12+6)^2]. 5 different surfaces are used (the two short walls, one long wall, the ceiling, and the floor). I think that is the shortest (also the wording of the actual problem implies that it is).
  23. Dec 23, 2007 #22
    If the fly has to walk, then it has to cover the distance through the walls. Had it been able to fly, the answer would have been sqrt(30^2+10^2) ~ 31.6227766016838. The reason for this is, the vertical height is 12, and the fly sites 1 foot below the ceiling (11 feet). It wants to go the 1 feet above the ground, i.e. the total vertical distance difference is thus 10.
    Now, whether the fly gets to the top or the bottom of the starting wall, the least distance to the other wall is the straight distance (30), i.e. the perpendicular distance.
    It has to travel another 1 to get up to the ceiling, and 10 more to get down to 1 feet after reaching the other side.
    Regards,
    Sleek.
  24. Dec 23, 2007 #23
    @ehrenfest
    I think i get it too. Maybe 40 is the shortest. I'll look into it when I get a bit more time :).
    Regards,
    Sleek.
  25. Dec 23, 2007 #24
    Dick
    I got those numbers by temporarily losing the ability to add correctly. But I see your sqrt[(1+30+1)^2 + (12+12)^2] now. On my diagram that route looked longer than the sqrt(37^2+17^2) one. Apparently I should try harder to draw to scale in a problem like this.
  26. Dec 23, 2007 #25
    Shooting Star
    So, what shall we decide on the answer to be? The sooner the better, otherwise this thread will ramble on and the original interesting question will be forgotten.
