Minimun Power needed
  • Thread starter arpsachin2
arpsachin2
A fan accelerates 2 m^3/min of air from rest to a velocity of 15 m/s. If the density of air is 1.25 kg/m^3, determine the minimum power that must be supplied to the fan?
Need some hints or something.
Answers and Replies
tiny-tim
25,838
255
welcome to pf!
hi arpsachin2! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
hint: momentum :wink:
arpsachin2
Thank you.
Okay a bit more I guess. :(
chemisttree
692
You can convert the volume of air to mass using density.
tiny-tim
25,838
255
(just got up :zzz: …)
force = rate of change of momentum
power = force times … ? :wink:
arpsachin2
Power = force * velocity
Am I heading the right way?
Fan accelerates at 2m^3/60 secs to 15 m/s
And density is 1.25kg/m^3.
So is it Power = 1.25kg/m^3 * Acceleration?
How do I get the acceleration?
tiny-tim
25,838
255
hi arpsachin2! :smile:
yes :smile:
and now you've totally lost me! :confused:
you don't need the acceleration!
you only need the force, and you can get that from the change in momentum :smile:
arpsachin2
if possible could you show me an example or something?
Thanks
arpsachin2
yes :smile:
Hey,
would it be possible to chat on Gmail or yahoo or something?
Please
arpsachin2
yes :smile:
So change in momentum is
Final momentum - Initial Momentum right
So, would it be 15 m/s - xxxx?
tiny-tim
25,838
255
15 m/s is a speed, you need a momentum (= mass times speed), in kg m/s,
and then you need a rate of change of momentum, in kg m/s2
Suggested for: Minimun Power needed
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
