Homework Help: Minkowski diagram: angles.
  1. Sep 9, 2016 #1
    In a diagram where I have two observers (one still (A) and one moving with a "v" velocity (B)), where the two parts disagre in the simultaneity of events, how can I prove that the angles of the B person axis that are put in the A person axis are equal. (/alpha=/beta , in the image U'.)
    2. Relevant equations
    3. The attempt at a solution
    I tried to show that the angles /alpha and /beta follow the same rate of change because the velocity of the B person is constant. Is it because the speed of light goes in a 45° angle? Do I need to calculate something?
  3. Sep 10, 2016 #2
    Andrew Mason
    Welcome to PF Powergade!
    Forget what I said in my earlier post about trying to find the angle of the axes to the line x = ct using the Lorentz transformations. It is much simpler.
    Use the Lorentz transformation find the equation for the t' and x' axes in terms of x and t (hint: the x' axis is defined by t' = 0). Then find the slopes of each of those axes (dx/dt) and compare them.
    AM
Have something to add?
Draft saved Draft deleted
