1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
MIPS help
  1. May 26, 2013 #1
    Hello i need to write a program that computes the value of sum numbers using a recursive subroutine
    and also i need to print the address of $sp every few steps..
    this is the code ive wrote so far but i cant get the result and i also dont know how to print $sp address
    Code (Text):
           .text
            .globl main
    main:
            subu    $sp, $sp, 32            # 32-byte stack frame
            sw      $ra, 20($sp)            # save return address
            sw      $fp, 16($sp)            # save frame pointer
            addu    $fp, $sp, 32            # set new frame pointer
    START:
            la      $a0, str_1              # system call to print str_1
            li      $v0, 4
            syscall
            li      $v0, 5                  # system call to read an integer
            syscall
            beq     $v0, $0, EXIT           # check if integer > 0
            move    $a0, $v0                # $v0 keeps the input value
            jal     SUM                     # call sum(), ra <- next PC
            la      $a1, result             # result is stored in $v0
            sw      $v0, 0($a1)             # store the value into memory
            la      $a0, str_2              # system call to print str_2
            li      $v0, 4                  # call number 4
            syscall
            EXIT:
            la      $a0, str_3
            li      $v0, 4                  # system call to print str_3
            syscall
            lw      $ra, 20($sp)            # restore return address
            lw      $fp, 16($sp)            # restore frame pointer
            addu    $sp, $sp, 32            # adjust stack pointer
            jr      $ra                     # return to caller 'main'
            jr      $ra
    SUM:
            addu    $fp, $sp, 32            # set up a new frame pointer
            sw      $a0, 0($fp)             # save sum(n) function argument n
            lw      $s2, 0($fp)              # read sum(n) function argument n
            bgtz    $s2, Loop2               # branch if n>0
            j       Loop1
    Loop2:
            lw      $s3, 0($fp)              # read sum(n) function argument n
            subu    $s2, $s3, 1               # n <- n-1
            move    $a0, $s2
            jal     SUM
            add     $s2, $s2, $s3              # compute sum(n-1)+n
    Loop1:
            lw      $ra, 20($sp)
            lw      $fp, 16($sp)
            addu    $sp, $sp, 32
            jr      $ra
                  .data
    str_1:  .asciiz "Enter the number for sum of n (0 to exit) => "
    str_2:  .asciiz "The serial result is  "
    str_3:  .asciiz "\n"
            .align 2
    result: .space 4
    any suggestion will be appreciate..
  3. May 26, 2013 #2
    ive just added this
    la $a0, 0($s2) # system call to print interer(result)
    li $v0, 1
    syscall
    right before EXIT:
    and when i run the simulation i get this message
    Enter the number for sum of n (0 to exit) => 3
    The serial result is 6
    but also i get
    Go: execution terminated with errors.
    Error in : invalid program counter value: 0
    Step: execution terminated with errors.
Have something to add?
Draft saved Draft deleted
Similar Discussions: MIPS help
  1. Mips subroutines (Replies: 1)
  2. Relocation Table MIPS (Replies: 4)
Loading...
