- 20
Hi there,
Not sure if this is the right place to post, but I seem to get a runtime error that says: address out of range 0x00000000. I think that it's probably in the first three lines of my code, but any idea as to what else it may be? Thanks so much!
Code:
.data
save: .word 1,2,4
.text
swap: sll $t1, $a1, 2 #shift bits by 2
add $t1, $a1, $t1 #set $t1 address to v[k]
lw $t0, 0($t1) #load v[k] into t1 <--- ERROR
#lw $t2, 4($t1) #load v[k+1] into t1
#sw $t2, 0($t1) #swap addresses
#sw $t0, 4($t1) #swap addresses
jr $ra #return
sort: addi $sp, $sp, -20 #make enough room on the stack for five registers
sw $ra, 16($sp) #save the return address on the stack
sw $s3, 12($sp) #save $s3 on the stack
sw $s2, 8($sp) #save Ss2 on the stack
sw $s1, 4($sp) #save $s1 on the stack
sw $s0, 0($sp) #save $s0 on the stack
move $s2, $a0 #copy the parameter $a0 into $s2 (save $a0)
move $s3, $a1 #copy the parameter $a1 into $s3 (save $a1)
move $s0, $zero #start of for loop, i = 0
for1tst: slt $t0, $s0, $s3 #$t0 = 0 if $s0 S $s3 (i S n)
beq $t0, $zero, exit1 #go to exit1 if $s0 S $s3 (i S n)
addi $s1, $s0, -1 #j - i - 1
for2tst: slti $t0, $s1, 0 #$t0 = 1 if $s1 < 0 (j < 0)
bne $t0, $zero, exit2 #$t0 = 1 if $s1 < 0 (j < 0)
sll $t1, $s1, 2 #$t1 = j * 4 (shift by 2 bits)
add $t2, $s2, $t1 #$t2 = v + (j*4)
lw $t3, 0($t2) #$t3 = v[j]
lw $t4, 4($t2) #$t4 = v[j+1]
slt $t0, $t4, $t3 #$t0 = 0 if $t4 S $t3
beq $t0, $zero, exit2 #go to exit2 if $t4 S $t3
move $a0, $s2 #1st parameter of swap is v(old $a0)
move $a1, $s1 #2nd parameter of swap is j
jal swap #swap
addi $s1, $s1, -1
j for2tst #jump to test of inner loop
j print
exit2:
addi $s0, $s0, 1 #i = i + 1
j for1tst #jump to test of outer loop
exit1:
lw $s0, 0($sp) #restore $s0 from stack
lw $s1, 4($sp) #resture $s1 from stack
lw $s2, 8($sp) #restore $s2 from stack
lw $s3, 12($sp) #restore $s3 from stack
lw $ra, 16($sp) #restore $ra from stack
addi $sp, $sp, 20 #restore stack pointer
jr $ra #return to calling routine
.data
space:.asciiz " " # space to insert between numbers
head: .asciiz "The sorted numbers are:\n"
.text
print:add $t0, $zero, $a0 # starting address of array
add $t1, $zero, $a1 # initialize loop counter to array size
la $a0, head # load address of print heading
li $v0, 4 # specify Print String service
syscall # print heading
out:
li $v0, 1 # specify Print Integer service
la $a0, space # load address of spacer for syscall
syscall # output string
addi $t0, $t0, 4 # increment address
addi $t1, $t1, -1 # decrement loop counter
bgtz $t1, out # repeat if not finished
jr $ra # return
