Mirror Word Problem: Focal Length & Image Characteristics
In summary: This means that a convex mirror was not used and the image was formed by the concave mirror. In summary, three physics students conducted an experiment on the roof of a building to determine the focal length of a concave mirror. They found the average of several measurements and concluded that the focal length was 17.5 cm. In the classroom, they confirmed that the mirror was concave by placing an object outside the focal length and observing a real, inverted, and diminished image.
~christina~
(a) On a sunny afternoon in April, three physics students took a mirror and a screen to the roof of a building. They selected a distant building, and while one student held the mirror a second one adjusted the distance between the screen and the mirror in an attempt to form a clear image of the building on the screen. Once the clear sharp image was formed on the screen, the third student made a measurement several times, took the average of these measurements, and then concluded that the focal length of the mirror is 17.5 cm.
(i) Describe the measurement made and explain how this measurement gives the focal length of the mirror.
(ii) What type of mirror did the students take to the roof?
(iii)Was the image on the screen real or virtual?; upright or inverted?; enlarged or reduced?
(b) Upon returning to the classroom, the students placed the mirror on an optical bench. An object was placed 22 cm in front of the mirror. Is an image formed on the screen for this object distance? If no, explain. If yes, find the characteristics (that is, the location, orientation, magnification, etc.) of the image formed.
I say it's a concave mirror.
It's inverted, and reduced as well. and the image is a real image.
Are my ideas right?
Thanks
I was thinking that the reason that they could make an average measurement was that the building was an infinately far distance away and thus the focal point was also the point that the image was able to be seen on the screen at.
And that the image could not have been viewed with a convex mirror or a flat mirror as well but only with a concave mirror because that is the only mirror which would allow the light rays to converge on one point which would allow for the image to be reflected onto the screen. (not only that, the focal length is possitive and so it couldn't be a convex mirror in the first place)
right or no?
Thank you
The fact that a real image is projected onto the screen in part 1 suggests you have a concave mirror.
When an object is placed outside the focal length of the mirror in part 2, the image is real, inverted, and diminished.
1. What is the mirror word problem?
The mirror word problem is a physics concept that involves understanding the relationship between an object, a mirror, and the resulting image. It is commonly used when studying optics and the behavior of light.
2. What is the focal length of a mirror?
The focal length of a mirror is the distance between the mirror and the point where all reflected light rays converge. It is an important characteristic of a mirror and determines the size and orientation of the resulting image.
3. How is the focal length of a mirror related to image characteristics?
The focal length of a mirror directly affects the size and orientation of the resulting image. A longer focal length will produce a smaller image, while a shorter focal length will produce a larger image. The orientation of the image will also be inverted (upside down) if the focal length is positive and upright (right side up) if the focal length is negative.
4. How can I calculate the focal length of a mirror?
The focal length of a mirror can be calculated using the mirror word problem formula: 1/f = 1/di + 1/do, where f is the focal length, di is the distance from the mirror to the image, and do is the distance from the mirror to the object. This formula is also known as the mirror equation.
5. What are some real-life applications of the mirror word problem?
The mirror word problem has many practical applications, including in the design of optical devices such as telescopes, cameras, and mirrors used in solar energy systems. It is also used in medical imaging techniques like MRI and ultrasound, as well as in everyday objects like mirrors and eyeglasses.
22K
