Missing bubbles in a pipette
  • B
  • Thread starter fresh_42
10,987
Summary:
How exactly does the capillary action work in this case?
I have observed the following phenomenon:
Step 1: Dunk the pipette into the solution.
Step 2: Press it and hold it pressed.
Step 3: Pull out the pipette, until the lower end is in the air.
Step 4: Release the pressure.
Now one would expect that the solution in the pipette sucks bubbles of air. However, it does not. The solution in the pipette climbs as if there was still a fluid to suck in. Why? O.k. it is presumably capillary action which is responsible, and the fluid has to climb until the pressures are equalized. But where are the bubbles?
  • Wow
Likes scottdave and Adesh
Answers and Replies
If we expect to see bubbles, it's because we are assuming that the fluid wants to stick to a fixed place on the pipette's wall, and therefore the air has to force the liquid to bulge upwards in the middle.
But if the liquid doesn't mind sliding upwards, then it can just act as a piston. So I'd guess it depends on how much the liquid wets and adheres to the wall. Something to do with : https://en.wikipedia.org/wiki/Wetting
Another possibility that seems intuitively plausible is this: if the liquid layer is fairly thin, then it will bubble. If it's thick, it will slide like a piston. If this turns out to be true, then it might imply that the adhesion (resistance to sliding) is contributed by the interface between the wet and dry parts, while the tendency to slide easily is dominated by the wet part. If the liquid layer is thick, the latter might be stronger.
So the outcome (sliding vs bubbling) might depend on an interaction between wetting, surface tension and geometry. E.g. a larger diameter tube might show more bubbling tendency compared to a narrow one.
Likes Lnewqban
Related Threads on Missing bubbles in a pipette
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
