• Support PF! Buy your school textbooks, materials and every day products via PF Here!
MIT Quantum Physics Problem Set 1
  • Thread starter lekh2003
lekh2003
264
2. Relevant equations
I've used:
##mv^2/r## = Centripetal
##q^2/r^2## = Force pulling the electron in
A bunch of other ones which I really can't be bothered listing.
3. The attempt at a solution
I managed to get Part A of the question using pretty simple methods.
I set ##mv^2/r = q^2/r^2##
That gave me ##v = sqrt(q^2/mr)##
And I plugged that into the equation for KE and got ##q^2/2r##
Then I need to transform the change in energy to the energy lost per orbital, so I used the time it takes to take each orbit using some orbital formula: ##t=2πr/v##
Keep going, and keep going, and eventually I found an equation for the change in energy due to radiation of energy, which I compared as a ratio to the kinetic energy, and it was basically negligible as an effect.
But Part B is beating me up. I really don't understand what to do. I was suspicious I must find a correlation between the energy and the radius, so I checked the solution and I got this:
However, I simply don't understand how they seemed to get these magical values.
After this, its some differential equations which I might have trouble understanding later, but right now I dont understand this step and what they're doing.
Thanks.
DrClaude
Mentor
6,817
2,937
Could you clarify where you think the magic appears? Considering that you have found yourself the equation for KE, the derivation in the picture is quite straightforward.
lekh2003
264
I understad where K comes from. But why do we take away from K what is essentially 2K. What is ##q^2/r##?
Can you tell us what exactly your doubt is? The ##q^2/r## is potential energy of electron in system where k=1
lekh2003
264
I apologize, I don't think I have my thoughts compiled very well.
Why is Energy = KE - PE, like E = ##q^2/2r - q^2/r##?
Also another issue I see, which might be separate is, why do they ignore constants here? Coulomb^2/metres is obviously not energy, but why are the constants that maintain dimensional accuracy eliminated?
DrClaude
Mentor
6,817
2,937
As always, Energy is KE + PE. KE is ##q^2/r##, as you calculated yourself. As for the potential energy, it is the Coulomb interaction between two charges ##+q## (the nucleus) and ##-q## (the electron), hence ##U = -q^2/r##. (##q## is here the elementary charge).
They are not ignoring constants here, but rather are using the theoreticians favourite units for electromagnetism, Gaussian units. So the charge ##q## is in statcoulomb, ##r## in centimetre, and ##q^2/r## will be an energy in ergs.
lekh2003
264
As always, Energy is KE + PE. KE is q2/rq2/rq^2/r, as you calculated yourself. As for the potential energy, it is the Coulomb interaction between two charges +q+q+q (the nucleus) and −q−q-q (the electron), hence U=−q2/rU=−q2/rU = -q^2/r. (qqq is here the elementary charge).
Ohhh. That makes sense. I don't seem to understand why I didn't realize that. Thanks.
They are not ignoring constants here, but rather are using the theoreticians favourite units for electromagnetism, Gaussian units. So the charge qqq is in statcoulomb, rrr in centimetre, and q2/rq2/rq^2/r will be an energy in ergs.
Ohhh, this is one of those things which would've been helpful knowing prior to jumping into the problem. I guess it all makes sense now. If I had done the prereq courses with MIT maybe it would be fine, but thanks for the help.
I'll keep working.
Want to reply to this thread?
"MIT Quantum Physics Problem Set 1" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
