catatonia
- 2
two-way analysis of variance
Hi, any insights regarding the accuracy of my analysis are welcome.
I used two-way analysis of variance (ANOVA) to do the analysis on 32 participants, who were either in the control group or in the divided attention condition; all subjects tried to memorize two types of faces (typical/distinctive faces). Dependent variable-"face" (typical and distinctive) independent variable- "condition"(control and divided attention).
During the analysis, under "Repeated measures", I moved the factors "typical" and "distinctive" into "within subjects variables', and "condition" into "between subjects factors"; then under "Repeated measures: Profile plots" I moved "condition" into "horizontal axis" (Should I have moved it into "separate plots" instead?)..then under "options" i selected "compare main effects". After that, I conducted a "simple effects analysis"---Under "independent sample t-tests" I moved "typical" and "distinctive" into "test variables" and "condition" into "grouping variable".
What do you think? If you need more details, let me know. Thanks.
