Mixing Steam & Ice: Solving Qgain=-Qlost
In summary, the equation Qgain=-Qlost is used to calculate the energy used to heat water to a certain temperature.
tanzerino
48
[PLAIN]http://img706.imageshack.us/img706/981/piccj.png
I tried writing the equation Qgain=-Qlost but i don't know how to deal with steam it doesn't have a (c)
tanzerino said:
I tried writing the equation Qgain=-Qlost but i don't know how to deal with steam it doesn't have a (c)[/QUOTE]
I'm not sure what you mean by "doesn't have a (c)"; are you referring to specific heat capacity?
perhaps you could use Q=ml for the steam; as it will begin to cool and form water, and the question states 'the heat of fusion of ice is 3.33e5 J/kg'.
Remeber for the specific heat capacity of water to use grams instead of kilograms (it's the Chemist's fault!)
You have the correct approach, the ice takes in a certain energy to melt the steam gives out a certain energy when it condenses.
Then you have hot and cold water to simply find the resulting temperature of.
(since the ice is at 0 and the steam at 100 - you don't need to worry about c for ice/steam since they don't change temperature)
i don't understand how i can not worry abt the c for ice/steam how woul the qgain=-qlost look like without c for steam. mass of steam multiplied change in temp only :s
25*3.33e5+25*4186*100+25*2.26e6=-(5*(tf-100))
melt 25kg of ice uses= 25*3.33e5 J/kg = 8.325 MJ
condense 5kg of steam gives 5*2.26E6J/kg = 11.3MJ
So we know we have enough energy to melt the ice and we will end up with liquid water!
Now we just have a simple energy start = energy at end question.
To simplify we will work from 0degC, so we say that water at 0deg has no energy
Before (11.3 - 8.325)MJ + 5kg*100C*4186J/kg/C = 5.06MJ
and this goes to heating the 30kg of water from 0C
ok so i did some wide shots but i donno.i tried this the specific heat for water vapour at constant volume is 31.4 for each mole and the 5 kg of steam has 18*5000 moles so the quation becomes:
25*3.33e5+25*4186*100+25*2.26e6=-(5000*18*31.4(tf-100)) which gives temprature of 73 celcius close but not an answer:(
so your way gives 40.3 which is approximately one of the answers
i didnt quite understand the last step though
so Before (11.3 - 8.325)MJ is equalizing the whole system into water and this is the excess energy used in heating water what is the 5kg*100C*4186J/kg/C = 5.06MJ
Any idea?
i get it now so we balanced them all into one 30kg mixture at 0 celcius and check the excess energy that will heat the mixture.the melting of ice consumed some heat but condensation of steam or the energy inside steam was much greater which provided extra energy but after condensation the steam is a 100 so it will still give out energy to become 0 c and calculating all this extra energy and use it to heat the water at 0c.Thanks a lot ,though not sure if it is definetaly correct cause kinda complicated any say on that?.
1. How does mixing steam and ice solve the equation Qgain=-Qlost?
Mixing steam and ice allows for the transfer of thermal energy between the two substances. As the steam condenses and turns into liquid water, it releases energy (Qgain) to the surrounding environment. At the same time, the ice absorbs this energy (Qlost) and begins to melt. This transfer of energy balances out the equation Qgain=-Qlost.
2. What is the significance of Qgain=-Qlost in the context of mixing steam and ice?
The equation Qgain=-Qlost represents the conservation of energy principle, where the energy gained by one substance is equal to the energy lost by another. In the case of mixing steam and ice, this equation shows that the total amount of thermal energy remains constant throughout the process.
3. Can steam and ice be mixed in any proportion?
No, steam and ice cannot be mixed in any proportion. In order for the equation Qgain=-Qlost to be satisfied, the mass of steam and ice must be in a specific ratio. This ratio is determined by the latent heat of fusion and vaporization of water, which is the amount of energy needed to melt or vaporize a certain mass of ice or steam, respectively.
4. How does the temperature change during the mixing process?
The temperature of the steam and ice will change during the mixing process. As the steam condenses and releases energy, its temperature will decrease. Similarly, as the ice melts and absorbs energy, its temperature will increase. However, at the end of the process, the final temperature of the mixture will be the same as the initial temperature of the steam (assuming no heat loss to the surroundings).
5. What other factors can affect the mixing of steam and ice?
Other factors that can affect the mixing of steam and ice include the initial temperatures of the steam and ice, the mass of each substance, and the efficiency of the heat transfer process. Additionally, external factors such as pressure and the presence of impurities in the substances can also impact the mixing process.
