Homework Help: Modeling Ballistics
  1. Sep 6, 2008 #1
    A child running along level ground at the top of a 30-ft-high vertical cliff at a speed of 15 ft/s, throws a rock over the cliff into the sea below. Suppose the child's arm is 3ft above the ground and her arm speed is 25ft/s. If the rock is released 10ft from the edge of the cliff at an angle of 30 degrees, how long does is take for the rock to hit the water? How far from the base of the cliff does it hit.
    2. Relevant equations
    V=initial velovity
    a=alpha=radians measurement of angle
    t=time
    s=initial height
    g=gravity=32ft/s
    x(t) = (V*cos(a))t
    y(t) = -(1/2)g(t^2)+(V*sin(a))t+s
    3. The attempt at a solution
    I have identified these variables:
    Variables I know:
    V=25ft/s
    s=3ft
    a=pi/6
    I also have solved 1 of the questions, time of flight by solving for this equation:
    0 = -16t^2+(25/2)t+33
    t=1.8789s
    Now trying to use t for the range I get
    x = (25* cos(pi/6))1.8789 =(approx) 40.680244
    To get the distance from the base of the cliff, I subtract the distance from the edge from the range:
    Distance to bas of cliff = 40.680244 - 10
    But this is incorrect can anyone please help, I have been at this for hours and it seems so basic.
  3. Sep 7, 2008 #2
    Redbelly98
    Staff Emeritus
    That's the velocity of her arm, but you need the velocity of the rock. You'll need to combine the arm and child velocities -- and remember, they are vectors.
  4. Sep 7, 2008 #3
    So do you mean that the initial velocity(V) for both equations should be 40ft/s?
  5. Sep 7, 2008 #4
    HallsofIvy
    No. The childs speed, 15 ft/sec, is horizontal only. As a vector it is <15, 0>. The initial velocity of the rock, relative to the child, is your <25 cos(30), 25 sin(30)>. Add those to find the velocity of the rock, relative to the ground.
    And let's hope that child stops running before she gets to the edge of the cliff!
  6. Sep 7, 2008 #5
    Right, so I get a velocity vector back how do I change this to a scalar quantity? Take the magnitude I would presume?
    You know that the strange part is I got the correct answer for "Time of flight" using the initial velocity of 25ft/s.
  7. Sep 7, 2008 #6
    Redbelly98
    Staff Emeritus
    Treat the horizontal and vertical directions independently.
    Horizontal: vi = [15 + 25 cos(30)] ft/s
    Vertical: vi = 25 sin(30) ft/s
    When I read the first part of the question,
    "A child running along level ground at the top of a 30-ft-high vertical cliff at a speed of 15 ft/s, ..."
    I thought we would be ask to calculate, coldly and objectively, her trajectory as she fell screaming onto the rocks below. :eek:
  8. Sep 7, 2008 #7
    HallsofIvy
    Which will hit first, the child or the rock?
  9. Sep 8, 2008 #8
    But how do I get the rock's initial velocity if I treat the 2 vectors separate? I need a scalar quantity(not a vector) for the rocks initial velocity with respect to the earth.
  10. Sep 8, 2008 #9
    O gosh I am an idiot "V" in my equation above is not initial velocity rather initial speed.
    so my equations are as follows
    [tex]
    x \left( t \right) = \left( \nu_0 cos \alpha \right) t \newline\newline
    x(t)\, is\, horizontal\, component\, of\, \mathbf{R} \left( t \right) =
    [/tex]
  11. Sep 8, 2008 #10
    [tex] \displaymath x \left( t \right) = \left( \nu_0 cos \alpha \right) t\, and \,y(t) = \frac{-1}{2}gt^2 + (\nu_0 sin \alpha)t +s_0[/tex]
    where x(t) and y(t) denote the horizontal and vertical components of
    [tex] \displaymath \mathbf{R} \left( t \right) = \left[ \left( \nu_0 cos \alpha \right) t \right] \mathbf{i} + [(\nu_0 sin \alpha)t - 1/2gt^2 +s_0] \mathbf{j}[/tex]
    g is gravity = 32[tex]\displaymath \frac{ft}{s^2}[/tex]
    [tex]\displaymath s_0[/tex] is initial height
    t is time
    [tex]\displaymath \nu_0 [/tex] is initial speed
    [tex] \displaymath \alpha [/tex] is angle of elavation
  12. Sep 8, 2008 #11
    Redbelly98
    Staff Emeritus
    Looks right to me.
  13. Sep 8, 2008 #12
    Well prb was due this morning and alas I didn't get the correct response for the range. I was suppose to add the initial horizontal velocity of 15 to the x(t) equation.
    I am sure you guys knew this but I couldn't see it, thanks for everyone's help.
Loading...
