Modern Physics
  1. Feb 7, 2006 #1
    Sir,
    The question is as follows:
    If excitation energy is provided by inelastic collisions between molecules, what is the temperature at which mercury vapour lamp will emit Ultra violet light of wavelength 2586 Angstrom?
    I tried applying Wein's displacement law(lamda * T = 2.898 *10^(-3)metre-Kelvin . I got the answer as 11000 Kelvin. But the answer given in my book is 55000 Kelvin.Here the symbol ^ represents power.Please help me in solving this problem.
  3. Feb 7, 2006 #2
    your answer should come out in kelvin only... not metre K.
    For the molecules in the gas they are MOST likely to have some speed (a formula exists for this). When TWO molecules (at a minimum) hit into each other (let's assume that) all their kinetic energy is converted into a photon (whose energy you can calculate).
    can you write the appropriate formulae for this?
  4. Feb 7, 2006 #3
    SpaceTiger
    Staff Emeritus
    Remember that the speed distribution of the molecules is given by the Maxwell-Boltzmann distribution, not the Planck distribution. Wein's displacement law gives you the peak intensity of a thermal spectrum of photons.
  5. Feb 10, 2006 #4
    Thank you sir. I have solved it with your help.
  6. Feb 11, 2006 #5
    why can a sphere be regarded as a point source?
  7. Feb 11, 2006 #6
    Gokul43201
    Staff Emeritus
    What is the context for this ? In most cases, the answer is in Gauss' Law.
  8. Feb 12, 2006 #7
    i am doing an experiment invesitigating the inverse square law of radiation using a bulb. a bulb is considered as a point source thus, a sphere. Please help.
  9. Feb 12, 2006 #8
    Gokul43201
    Staff Emeritus
    If this is an uncoated, incandescent bulb, then you are treating it as a point source because all the light comes from the tiny length of filament inside it. If this length is small comapred to the distances at which you are measuring the intensity, then it can be treated as a "point". This is an approximation, but usually a good one. And this has little to do with the fact the the bulb is shaped like a sphere - in fact, most bulbs aren't.
    However, if you did have a spherical body (like a planet or star or spherical phosphorescent bulb), then too, you can treat the radiation as coming from a point source centered with the body. The reason for this is that the radiation from the body mostly comes out in directions normal to the surface.
    If instead of a spherical body, you had a long, cylindrical body, then by the same argument, you could treat it as a line-source.
  10. Feb 13, 2006 #9
    thank you very much
