Modular Arith: How is Remainder 2?
  • Thread starter chwala
  • Tags
    Arithmetic
In summary, the conversation discusses the concept of modular arithmetic and how to determine remainders in this system. The experts explain that modular arithmetic involves defining an equivalence relation on the set of integers, and finding the smallest non-negative number that satisfies the quotient and remainder conditions. They also discuss the concept of inverses in modular arithmetic and how it relates to the given problem. The conversation ends with a discussion on the importance of understanding mathematical concepts in a way that stays with you.
chwala
351
how is -10≡2 mod 3?
modular arithmetic
ok this is a bit confusing to me, long since i did this things...-10/3=quotient -3+ remainder -1. How is the remainder 2?
By definition, this means that ##3## divides ##-10-2 = -12## which is trivially true.
What definition are you using?
i am not using any , is it that a=b mod c and a≡ b mod c imply different things? my interest is on the former. The latter i presume applies to congruence.
chwala said:
Problem Statement: how is -10≡2 mod 3?
Relevant Equations: modular arithmetic
##-1## means the inverse of ##1##. In mod 3 arithmetic ##1 + 2 = 0##, hence ##-1 = 2##.
More simply, ##-1 \equiv 2 (mod \ 3)##
If you want to talk about remainders in connection to modular arithmetic you should define the remainder of n/m to be the smallest non-negative number k such that the quotient (n-k)/m is an integer. With this definition you have the quotient -4 and the remainder 2.
Also, as has been pointed out already, -1 = 2 mod 3 so saying -10 = -1 mod 3 is also perfectly fine, -1 and 2 are in the same equivalence class.
Likes chwala
The reason is that multiples of three doesn't count anymore. The procedure is, that we impose a relation ##\sim## on the set of integers which is defined by: ##a\sim b## iff ##3## divides ##a-b## or iff ##a## and ##b## have the same sort of remainder: ##3\mathbb{Z}##, ##3\mathbb{Z}+1##, or ##3\mathbb{Z}+2##. We consider these sets as one element: ##[0]=3\mathbb{Z}##, ##[1]=3\mathbb{Z}+1##, ##[2]=3\mathbb{Z}+2##. The brackets ##[]## which indicates that entire sets are behind the numbers ##0,1,2## are usually not written, as they don't carry any additional information compared to what has already been said by using ##\operatorname{mod}## or ##\equiv##. The same is true for ##\equiv##: it is often just written as equality ##=##, an equality of sets, the so called equivalence classes with respect to ##\sim##.
In addition to what has already been stated (or perhaps I missed that this, too, has already been stated):
The statmment:
## a \equiv b \mod n ##​
means that there is some integer, ##m##, such that:
## a - b = mn ## .​
Regarding your question:
## -10 \equiv 2 \mod 3 ##
because
## (-10) - (2) = (-4)( 3) ##
ok meaning that say -20/3 will be -20≡1mod 3? where quotient is -7 and k=1
-50/3 will be -50≡1 mod 3? where quotient is -17 and k=1
so you're implying that k cannot be a negative integer, rather it has to be positive?
i don't understand what you're saying here on inverses...this is a relative new area to me as my area of maths is applied maths...
Do you understand why:
##-1 \equiv 2 (mod \ 3)##?
No, both -10 = -1 mod 3 and -10 = 2 mod 3 are valid statements as -1 = 2 mod 3.
i figured out a way of doing this things...lets say you have a≡ k mod b then it follows that,
{a-k}/{b}= integer value...positive critism is welcome.
This is just the definition of a ~ k (mod b). See, for example, post #7.
Likes chwala
thanks seen, i appreciate.
{a-k}/{b}= integer value...positive criticism is welcome.
Yes, this is correct.
In post #2, @Math_QED gives this for the specific case in which ##a=-1,\ k=2, \text{ and } b=3## .
Also, as @Orodruin mentioned, I gave a definition equivalent to yours in Post #7.
The more important issue here is that you now have a very solid way of thinking of modular equivalence (congruence), at least as it applies to integers. Congratulations on this!
Likes chwala
The reason why we define the remainder to positive follows from a few key ideas. Do you know what an equivalence class is? Do you know how elements of congruence mod n look like? and how many are there?
The reason that the reduced residue (the remainder) must be positive follows from the statement of the Division Theorem.
This is wrong. The representatives (remainders) do not have to be positive. This is out of convenience and not a mathematical necessity. Thus it doesn't follow from anything. One can perfectly calculate with ##\mathbb{Z}/2\mathbb{Z} =\{\,[17],[-12]\,\}## but it makes more fun to write it as ##\{\,[0],[1]\,\}##.
true. but usually we define remainders using the statement of the Division Theorem and showing that the relation congruence modulo n on Z is an equivalence relation. Using the definition of equivalence classes...
Since the elements of Zn are equivalence classes, then it does not matter which representative we use to denote the distinct equivalence classes (this is what you are saying).
Also, it helps establish the fact that a is congruent to r modulo n, where r is the reduced reduced residue of a.writing the remainders as positive helps us build more results of number theory in a "nice way."
Likes chwala
Right. I just wanted to prevent the impression that it has to be those representatives. This contradicted the entire concept of equivalence classes. Any are as good as specific ones, just not as easy to calculate with. And if we only consider the group property and forget about the ring, then ##\mathbb{Z}_2=\{\,0,1\,\}## can even be written multiplicatively as ##\mathbb{Z}_2=\{\,-1,1\,\}##.
Likes chwala
i took my time to look at the modular arithmetic and i could understand it straight away...i found it to be very easy stuff for me...i believe i can attempt any problem in math if i give it the necessary time and effort.:cool:
yap:cool:
...therefore in summary, from my study, if we have for instance, a mod b = c then it follows that increasing ##a## by a multiple of ##b## would result to the same remainder.
therefore,
##a mod b= (a+k.b)mod b## for any integer ##k##
for example,
3mod 10=3
13mod 10=3
23mod 10=3
-7mod10=3
bingo :biggrin::cool::cool:
Be careful! You will never again agree with people who say ##1+1=2## and expect this as a given truth!
  • Haha
Likes chwala
1. What is modular arithmetic?
Modular arithmetic is a branch of mathematics that deals with operations on integers and their remainders when divided by a fixed number, called the modulus.
2. How is remainder 2 calculated in modular arithmetic?
To calculate the remainder 2 in modular arithmetic, we need to divide the given integer by 2 and take the remainder. For example, the remainder 2 of 13 in modular arithmetic would be 1, as 13 divided by 2 leaves a remainder of 1.
3. What is the significance of remainder 2 in modular arithmetic?
The remainder 2 in modular arithmetic is significant because it indicates whether a number is even or odd. If a number has a remainder of 2 when divided by 2, it is an odd number. If it has a remainder of 0, it is an even number.
4. Can modular arithmetic be applied to negative numbers?
Yes, modular arithmetic can be applied to negative numbers. In this case, the remainder is always positive and less than the modulus. For example, the remainder of -5 when divided by 2 would be 1, as -5 divided by 2 leaves a remainder of -1, which is then converted to a positive remainder of 1.
5. How is modular arithmetic used in real-world applications?
Modular arithmetic has numerous real-world applications, such as in cryptography, computer science, and engineering. It is used to ensure data security, create unique identification numbers, and optimize computer algorithms, among other things.
  • Precalculus Mathematics Homework Help
