Modulo arithmetic
  • Thread starter Mentallic
Mentallic
3,798
94
I've stumbled across an arithmetic problem that's getting the better of me, so I need your help!
I have a constant set of integers [itex][m,n], m>0, m\neq n[/itex] and a variable integer k>0. If we multiply k by successively increasing positive integers t, we will eventually get kt > m. Now, what I want is the output to be kt if [itex]kt \in [m,n][/itex] and n if [itex]kt>n[/itex].
So for example, let's consider m = 45, n = 50 and k = 8.
We get the sequence 8, 16, 24, 32, 40, 48
At this point, we have a value larger or equal to m=45, and 48 < n=50 so the output is 48.
For k=11 we have
11, 22, 33, 44, 55
Since we now have a value larger than m, but the value is also larger than n, the output needs to be n=50.
So finally, my question is, can I create a function that isn't piecewise that defines this process? The piecewise function wasn't such a big deal,
f(k,m,n) =
\begin{cases}
\Big\lceil \frac{m}{k} \Big\rceil k, & \text{if}\hspace{5 mm} \Big\lceil \frac{m}{k} \Big\rceil k < n \\ \\
n, & \text{if}\hspace{5 mm} \Big\lceil \frac{m}{k} \Big\rceil k \geq n
\end{cases}
But I can't figure out how to produce a non-piecewise function.
Answers and Replies
12,838
[m,n] means the interval from m to n?
So t is the smallest integer t such that kt >=m?
You can implement min(a,b) (the smaller value of a and b) as (|a+b|-|a-b|)/2, I think that should help.
Mentallic
3,798
94
Yes and yes. Sorry, I should have been more clear when defining my variables.
That's perfect! Thanks mfb.
rcgldr
8,782
573
You can implement min(a,b) (the smaller value of a and b) as (|a+b|-|a-b|)/2.
Now a method to implement absolute value that isn't piecewise would be needed.
Mentallic
3,798
94
Good point, but this problem was actually for a computing project of mine and since the abs(x) function already exists as a library function, its piecewise definition isn't an issue.
rcgldr
8,782
573
For 32 bit signed two complement integers, and assuming the compiler does an arithmetic right shifts:
#define abs(a) ((a^(a>>31))+((a>>31)&1))
Related Threads on Modulo arithmetic
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
