Mohr's Circle
  • Thread starter Precursor
Precursor
222
Sketch the element for the stress state indicated and then draw Mohr's circle.
Given: Uniaxial compression, i.e. [tex]\sigma_{x} = -p[/tex] MPa
The attempt at a solution
Below I have the sketch and a partially complete Mohr's circle:
[PLAIN]http://img710.imageshack.us/img710/6001/civek.jpg [Broken]
What am I missing on the Mohr's circle? Did I even go about this correctly?
Answers and Replies
Precursor
222
Any ideas?
vela
Staff Emeritus
Education Advisor
15,563
2,204
First, tell us what [itex]\sigma_y[/itex] and [itex]\tau_{xy}[/itex] are equal to.
Precursor
222
The thing is, they don't provide [tex]\sigma_{y}[/tex] or [tex]\tau_{xy}[/tex], which is why I was confused.
vela
Staff Emeritus
Education Advisor
15,563
2,204
Well, the problem says the compression is uniaxial. What does uniaxial mean?
Precursor
222
That would mean having a single axis, so [tex]\sigma_{y}[/tex] is not involved here. But how about [tex]\tau_{xy}[/tex]? I simply assumed it existed, as you can see in my drawing of the Mohr's circle.
vela
Staff Emeritus
Education Advisor
15,563
2,204
I'd take it to be 0 as well.
Precursor
222
If [tex]\tau_{xy} = 0[/tex] then there wouldn't even be a circle. Would it be a straight line?
vela
Staff Emeritus
Education Advisor
15,563
2,204
No, you always get a circle. The two points you know are on the circle will be [itex](\sigma_y,\tau_{xy}) = (0,0)[/itex] and [itex](\sigma_x,-\tau_{xy})=(-p,0)[/itex]. Now you go about the same procedure as before and find the location of the center of the circle, its radius, etc.
Precursor
222
So in my sketch I should remove the shear stress arrows?
vela
Staff Emeritus
Education Advisor
15,563
2,204
Sure, or label them as being equal to 0.
Precursor
222
I found the centre to be [tex](\frac{-p}{2},0)[/tex] and the radius to be [tex]\frac{p}{2}[/tex]. Is this correct.
vela
Staff Emeritus
Education Advisor
15,563
2,204
Yes, that's correct.
Precursor
222
How do I find the line X'Y' since I don't know the angle [tex]\theta[/tex]?
vela
Staff Emeritus
Education Advisor
15,563
2,204
What are X, Y, X', and Y' supposed to denote?
Precursor
222
These 4 variables are points on the Mohr's circle denoted by:
X:([tex]\sigma_{x},-\tau_{xy}[/tex])
Y:([tex]\sigma_{y},+\tau_{xy}[/tex])
X':([tex]\sigma_{x}',-\tau_{xy}'[/tex])
Y':([tex]\sigma_{y}',+\tau_{xy}'[/tex])
There are equations used to solve for X' and Y', but one of the variables is [tex]\theta[/tex], which isn't given.
vela
Staff Emeritus
Education Advisor
15,563
2,204
OK. Did the problem ask you to find the axial and shear stresses for some plane?
Precursor
222
That's part b of the question, which askes me to determine the maximum shear stresses that exist and to identify the planes on which they act by drawing the orientation of the element for these normal stresses.
But actually, [tex]\theta=0[/tex] because the angle between the line XY and the x-axis is 0.
vela
Staff Emeritus
Education Advisor
15,563
2,204
What points on the circle correspond go the orientation when the shear stress is maximized?
Precursor
222
Would that be the points where the circle is at the highest and lowest in the y direction?
vela
Staff Emeritus
Education Advisor
15,563
2,204
OK, I'm still not clear on exactly what you're trying to do with (X', Y') and θ.
Precursor
222
2θ is what separates the lines XY an X'Y'. I think since θ = 0, there isn't an X'Y' line.
vela
Staff Emeritus
Education Advisor
15,563
2,204
When you draw Mohr's circle, typically you start with the axial and shear stresses for a given orientation of the element, so you know where the points X and Y lie on the diagram. Where X' and Y' lie depend on what you're trying to find. For instance, if you're interested in the principal axes, you'd choose to have X'Y' lie on the horizontal axis. If you wanted to find where the shear stress is maximized, you'd choose X'Y' so that it was vertical.
Precursor
222
For part c of the question, it asks me to sketch the element for the stress state and draw the Mohr's circle for the case of a biaxial compressive stress, i.e., [tex]\sigma_{x}=\sigma_{y}=-p[/tex] MPa.
I found the radius to be 0. Does that mean it's simply a point, instead of a cricle?
vela
Staff Emeritus
Education Advisor
15,563
2,204
Yes.
Precursor
222
For the case of uniaxial compression([itex]\sigma_{x}=-p[/itex]) I am asked to determine the maximum shear stresses, and to draw the orientation of the element for these normal stresses. Below I have what I think it should be. Is it correct?
[PLAIN]http://img404.imageshack.us/img404/116/cive2.jpg [Broken]
vela
Staff Emeritus
Education Advisor
15,563
2,204
No, that's not correct. First, what are the axial and shear stresses equal to when the shear stress is maximized? What angle do you have to rotate by on Mohr's circle to reach those points? How does that translate to the orientation of the element?
Precursor
222
Here is my Mohr's circle for this case.
[PLAIN]http://img710.imageshack.us/img710/4182/cive3.jpg [Broken]
The centre point corresponds to [itex](\frac{-p}{2},0)[/itex]
Therefore, the maximum shear stress occurs when the normal stress is [itex]\frac{-p}{2}[/itex]. So does that mean the angle of rotation is 90 degrees clockwise?
vela
Staff Emeritus
Education Advisor
15,563
2,204
Yes, you rotate by 90 degrees on Mohr's circle (clockwise or counterclockwise doesn't really matter).
Precursor
222
So will it look something like this:
[PLAIN]http://img190.imageshack.us/img190/8683/cive4.jpg [Broken]
  • #31
vela
Staff Emeritus
Education Advisor
15,563
2,204
No, that's not right. First, what are [itex]\sigma'_x[/itex], [itex]\sigma'_y[/itex], and [itex]\tau'_{xy}[/itex] equal to? Second, since you have to rotate by 90 degrees on Mohr's circle, that means [itex]2\theta=90^\circ[/itex], so [itex]\theta=45^\circ[/itex]. What do you suppose this 45 degrees corresponds to?
  • #32
Precursor
222
I believe there are formulas to solve for [itex]\sigma_x[/itex]', [itex]\sigma_y[/itex]', and [itex]\tau_{xy}[/itex]'.
Would the 45 degress correspond to the rotation of the element?
  • #33
vela
Staff Emeritus
Education Advisor
15,563
2,204
Yes, it's the angle through which the element is rotated. The stresses you should be able to read off of Mohr's circle. There's no need to resort to formulas for this problem.
  • #34
Precursor
222
So I use trigonometry to find those values?
  • #35
Precursor
222
So if I rotate on the Mohr's circle by 90 degrees I will reach the max and min shear stresses?
Suggested for: Mohr's Circle
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
