Mol fraction as a concentration?
In summary: Remember to always check your units and make sure they cancel out in the end. In summary, to find the mole fraction of C12H22O11 in a mixed solution, you need to calculate the moles of C12H22O11 in each individual solution, then add them together to get the total moles in the mixed solution. Finally, divide the moles of C12H22O11 by the total moles to find the mole fraction.
LuX
2 solutions of C12H22O11 are mixed. Solution A is .150M with density of 1.05 g/mL. Solution B is 10%
C12H22O11 by mass with density of 1.03g/mL. 100 mL of solution A is mixed with 100g of B. What is the mole fraction of C12H22O11 in the mixed solution?
mole fraction = (mol of A + mol of B)/ total mols and also (volume of A + volume of B)/total Volume
i tried converting both solutions into volumes and using the mole fraction formula regarding volumes to calculate mol fraction. but i doubt i got it right...
for volume of solution A : .100L (.150mol/L)(342.99g/mol)(1 mL/1.05g) = 4.899 mL
for B: 10g(1mL/1.03g) = 9.708737
mol fraction = 4.899/14.60 = .335
Your approach is on the right track, but there are a few errors in your calculations. Let's break down the steps to find the correct answer:
1. Convert the mass of solution B (100g) into volume:
100g x (1 mL/1.03g) = 97.087 mL
2. Calculate the total volume of the mixed solution:
100 mL + 97.087 mL = 197.087 mL
3. Calculate the moles of C12H22O11 in solution A:
.150 mol/L x .100 L = .015 mol
4. Calculate the moles of C12H22O11 in solution B:
10% of 97.087 mL = 9.7087 mL
9.7087 mL x (1 L/1000 mL) = .0097087 L
.0097087 L x (1 mol/342.99 g) = .0000283 mol
5. Calculate the total moles of C12H22O11 in the mixed solution:
.015 mol + .0000283 mol = .0150283 mol
6. Calculate the mole fraction of C12H22O11:
.0150283 mol / (.0150283 mol + .0000283 mol) = .9981
So the mole fraction of C12H22O11 in the mixed solution is 0.9981.
Yes, mol fraction can be used as a measure of concentration. In this case, it is used to determine the proportion of a specific substance (C12H22O11) in a mixture of two solutions. The mole fraction formula, which takes into account the number of moles and volumes of each solution, can be used to calculate the mol fraction of C12H22O11 in the mixed solution. However, it is important to make sure that the units are consistent and to double check the calculations for accuracy.
1. What is mol fraction as a concentration?
Mol fraction, also known as mole fraction, is a unit of concentration that represents the ratio of the number of moles of a particular substance to the total number of moles in a solution. It is typically expressed as a decimal or fraction.
2. How is mol fraction calculated?
To calculate mol fraction, you divide the number of moles of the substance you are interested in by the total number of moles in the solution. This can be represented by the formula: mol fraction = (moles of substance / total moles in solution)
3. What is the significance of using mol fraction as a concentration?
Mol fraction is a useful unit of concentration because it takes into account the relative amounts of different substances in a solution. It is also an intensive property, meaning it does not depend on the size or amount of the solution.
4. How is mol fraction different from other concentration units?
Unlike other concentration units, such as molarity or mass percent, mol fraction takes into account the relative amounts of all substances present in a solution. This makes it a more accurate representation of the concentration of a particular substance in a solution.
5. Can mol fraction be used to compare solutions with different volumes?
Yes, mol fraction can be used to compare solutions with different volumes because it is an intensive property that does not depend on the size or amount of the solution. This allows for a more accurate comparison of the concentration of a particular substance in different solutions.
