Understanding Molecular Collisions in Gases
In summary, the conversation discusses the concept of molecular collisions and how it relates to the behavior of gases. It is mentioned that molecules do not actually collide in the same way as billiard balls, but rather interact through their dipole moments and electron orbitals. The idea of using billiard balls as a model for molecules is questioned, particularly in regards to gases with viscosity.
Aero51
548
Hey, I'm not sure if this should be in the chemistry or physics section,. Hopefully it is in the right place. I have a question about molecular collisions: specifically, what actually happens when two molecules "collide". Perhaps a better question is: "what constitutes a molecular collision?". Since I have some background in physical gas dynamics and modern physics, I know that it is not possible for the two molecules to actually "touch" each other in the sense of two billiard balls colliding. On this subject, since molecules do not collide in the macroscopic sense, why do they behave as if they are, as stated earlier, billiard balls in a container? If anyone has good references or books please share those too!
It is sufficient to have any sort of non-destructive interaction to make "billard balls in a container" a good model. If molecules come close to each other, their dipole moments can influence each other via the electromagnetic interaction. If they come even closer, their electron orbitals begin to overlap, which (usually) generates a repulsive force.
If this is true then what about gases with viscosity? Wouldn't that require one to know (or assume) something about the geometry of the molecules?
1. What is a molecular collision in gases?
A molecular collision in gases refers to the interaction between two or more gas molecules when they come into contact with each other. It involves the exchange of energy and momentum between the colliding molecules.
2. How do molecular collisions affect the behavior of gases?
Molecular collisions play a crucial role in determining the physical properties of gases, such as pressure, temperature, and volume. The frequency and intensity of collisions determine the gas pressure, and the average speed of molecules after collisions determines the gas temperature.
3. What factors can influence the frequency and intensity of molecular collisions?
The frequency and intensity of molecular collisions can be influenced by factors such as temperature, pressure, and the number of gas molecules present. Higher temperature and pressure result in more frequent and intense collisions, while increasing the number of gas molecules increases the overall number of collisions.
4. How are molecular collisions related to the ideal gas law?
The ideal gas law, PV = nRT, is based on the assumption that gas molecules are in constant motion and undergo elastic collisions with each other and the walls of the container. Molecular collisions are therefore a fundamental concept in understanding and applying the ideal gas law.
5. Can molecular collisions be observed or measured?
Molecular collisions are too small and fast to be directly observed, but their effects can be measured through various techniques such as gas pressure and temperature measurements. Advanced technologies, such as molecular beam experiments, can also provide indirect evidence of molecular collisions.
  • Mechanics
  • Mechanics
