Homework Help: Moles of silver perchlorate
  1. Feb 8, 2006 #1
    I was given several equations to use for this assignment so, before assuming that I got this right, I wanted to check my answers. I don't think I have them done correctly...:redface:
    What is the molarity of a solution of silver perchlorate, AgClO4, if 3.2 moles of silver perchlorate are dissolved in 1.5 liters of water?
    molarity = moles/ volume
    molarity = 3.2/1.5
    molarity = 2.13
    How many moles of potassium iodide, KI, must be used to make 1.500 L of a 0.2 M solution?
    moles = 1.500/0.2
    moles = 7.5
    What is the molarity of the solution produced when 151 g of sodium chloride, NaCl, is dissolved in enough water to prepare .375 L of solution?
    molarity = grams/molar mass
    molarity = 151/.375
    molarity = 402.6
    How many grams of potassium chloride, KCl, are needed to prepare 0.630 L of a 2.50 M solution of potassium chloride?
    (2.50)(.630) = x/74.6
    1.575= 74.6x
    .021 = x
    .021 grams
  3. Feb 8, 2006 #2
    **Disclaimer**
    I've learned from the past that I need to warn you ahead of time that I may be incorrect. I hope I don't accidentally mislead you.
    Your work is correct, but make sure you check your significant figures.
    M = mol / L ; mol = L * M
    M = mol / L ; M = (g / molecular mass) / L
    In other words, convert grams to moles first, and then plug that into the original equation.
    You started it off right, but you finished it incorrectly. Think about it - you have moles, and you need to convert to grams. Using dimensional analysis, you would have to do:
    mol ( g / mol) so that moles cancel leaving you with grams. So, what do you think you should do?
  4. Feb 8, 2006 #3
    Gokul43201
    Staff Emeritus
    You have not (mislead).
  5. Feb 9, 2006 #4
    GCT
    kinsclair13 gave good explanations, for the third question you'll need to convert to moles, since molarity is moles/liter. The last one seems correct though, you'll need to find the moles, than simply convert from moles to grams using factor labeling.
  6. Feb 9, 2006 #5
    Gokul43201
    Staff Emeritus
    Actually, the only problem with the last one is an error in algebra. Double-check the math.
  7. Feb 9, 2006 #6
    Alright, let's see if I got this now... ^_^
    1. 2.1...molarity? Is that how you put it?
    2. .3 moles
    3. 6.88 molarity
    4. 117.4 grams
  8. Feb 9, 2006 #7
    Yeah, that was pretty stupid.:rofl: I did it correctly on my paper the second time around and then, when I compared it to my first answer I thought, "How on Earth did I screw that up?":yuck:
