Moment and a couple problem
  • Thread starter yoda2026
ive been trying to figure our this mechanics question and im rather stuck
but unfortunately i havent had much experience with moments
find the normal forces applied to the installed stud at points A and B
l-----360mm--l--85-l
A.====
P.=========== /==/
====.B
length from P to A = 360MM
length of A to B = 85mm
thickness of timber between A and B is 45mm (or vertical distance between A and B)
for applied at point P is 150N
ignore friction
so far i understand that the force applied to the centre of the stud
is 360/1000 * 150N = 54NM
then you have a couple of 85/1000 * 150N = 12.75nm
is this the correct way of attempting this question
if so how does the couple and the for applied to the lever interact to give me the force on points A and B of the stud?
Answers and Replies
tiny-tim
25,832
251
welcome to pf!
hi yoda2026! welcome to pf! :wink:
if the question is what i think it is :confused:, then you find the force at A by taking moments about B …
the moment about B of the force at P must be equal and opposite to the the moment about B of the force at A :smile:
so when you say the moment of about B
do you mean the moment of PB or the moment AB
tiny-tim
25,832
251
i'm sorry, i don't understand :redface:
the moment of a force F about a point B is F times the perpendicular distance from B to the line of the force
..................A.====
P.========== /==/
.....................====.B
sorry my diagram lost its formatting
i am trying to calculate for the force on points A and B
now the way i have been looking at it is that the force is 150N is applied to point P
so the moment between PA is 360mm x 150N = 54nm
this is where i get abit lost because points A and B form a couple producing 12.5NM
is the force applied to point B calculated from PB or is it PA-AB
or have i just got this totally backward
tiny-tim
25,832
251
hi yoda2026! :smile:
(just got up :zzz: …)
… now the way i have been looking at it is that the force is 150N is applied to point P
your language is completely wrong, which i think is why you're misunderstanding how moments work
there is no "moment between PA" :redface:
there is a moment of the force at P about the point A
in this case, the force is vertical, so the moment is the force times the horiztonal distance between P and A :wink:
ok, now you need the moments of all the other forces about A
clearly, the force at A has zero moment
and the moment of the force at B about the point A is … ? :smile:
im guessing it is 66.25nm
because the force experienced in the couple is equal in both directions
now to calculate the normal force i am totally stumped
because all these cals are in NM(which is a rotational force) and please correct me if im wrong but a normal force is a linear force and would be measured in Newtons
[PLAIN]http://img851.imageshack.us/img851/1826/photoc.jpg [Broken]
here is a actual copy of the diagram
i hope this makes it clearer
tiny-tim
25,832
251
(thanks for putting the diagram sideways :biggrin: … i hate it when people post diagrams that are too wide! :rolleyes:)
how did you get that? :confused:
yes :smile:
there isn't only a couple
at both A and B, there is a vertical force (the two normal forces which you are asked to find)
they are not equal: they form a couple plus a resultant linear force of 150 N (to balance the force on the handle)
let's say that the vertical force at B is V newtons …
how much is the moment of that force about A, and so what is V ? :wink:
Related Threads on Moment and a couple problem
  • Last Post
13K
  • Last Post
  • Last Post
24K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
