Moment of Inertia about an axis at the center of mass
In summary, the moment of inertia of the sphere about its mass centre is 2/5Mr^2, and the moment of inertia of the rod about its mass centre is 1/12ml^2.
JesseJC
49
3.) What is the moment of inertia of the object about an axis at the center of mass of the object? (Note: the center of mass can be calculated to be located at a point halfway between the center of the sphere and the left edge of the sphere.)
https://www.smartphysics.com/Content/smartPhysics/Media/Images/Mechanics/15/momentofinertia2new.png
mass of rod = 7.31kg
length of rod = 5.68m
radius of sphere = 1.42
mass of sphere = 36.55kg
1.) I about axis at left end of rod = 1960.4kg-m^2
2.) angular acceleration w/ 498N exerted perpendicular to center of rod = .72rad/s^2
I = 2/5mr^2, I = 1/12ml^2, I = Icm + Md^2 (?)
I've calculated the centre of mass, which ended up being about 6.4m, however, I am completely at a loss as to how I should approach the rest of the question. I'd really appreciate a bit of in depth help on this one! [/B]
Could you please restate the whole question, clearly? I'm not sure what's going on here.
An object is formed by attaching a uniform, thin rod with a mass of mr = 7.31 kg and length L = 5.68 m to a uniform sphere with mass ms = 36.55 kg and radius R = 1.42 m. Note ms = 5mr and L = 4R.
https://www.smartphysics.com/Content/smartPhysics/Media/Images/Mechanics/15/momentofinertia1new.png
1)
What is the moment of inertia of the object about an axis at the left end of the rod?
A: 1960.4kg-m^2
2)
If the object is fixed at the left end of the rod, what is the angular acceleration if a force F = 498 N is exerted perpendicular to the rod at the center of the rod?
A: .72rad/s^2
3)
A: ?, this is where I'm beginning to get lost, I'm not sure how to approach this part of the question at all
I calculated the CM like so -> Xcm = [(mr)(L/2) + (ms)(L+R)]/(mr + ms) = 6.4m, but can't conjure up any ideas for the rest of the question, I've tried various applications of the parallel axis theorem and so on, but not confidently, I don't have a solid idea about how moment of inertia about the centre of mass, or a body such as this works. What do the arrows and dotted lines imply? I understand that MOI determines the amount of torque needed to angularly accelerate an object, but I just don't understand all of the theoretical workings behind it.
You have quoted the three equations you need.
To keep it readable, please work symbolically ( r = radius, l = rod length, etc.; use two different symbols for the masses).
In terms of those symbols, try to answer these questions in sequence:
What is the moment of inertia of the rod about its mass centre?
How far is the rod's mass centre from the rotation axis?
What is the moment of inertia of the rod about the rotation axis?
Then the same questions for the sphere.
My post crossed with yours.
It isn't completely clear from the wording, but I believe the dashed line indicates the rotation axis. No idea what the arrow is for.
What is the moment of inertia of the rod about its mass centre? 1/12ml^2
How far is the rod's mass centre from the rotation axis? CM - l/2 or 6.4 - 2.84 = 3.56m
What is the moment of inertia of the rod about the rotation axis? 1/12m(CM - l/2)^2 ?
What is the moment of inertia of the sphere about its mass centre? 2/5Mr^2
How far is the sphere's mass centre from the rotation axis? r/2 ?
What is the moment of inertia of the sphere about the rotation axis? 2/5M(r/2)^2 ?
Let me know where I went wrong, I'm not confident in the answers followed by question marks.
No. As you posted in the OP
JesseJC said:
I = Icm + md2
You have correctly calculated Icm here as 1/12ml2.
d is the distance from the mass centre to the rotation axis.
ok, so the MOI with respect to the rod is 1/12ml^2 + md^2 ---> 1/12(7.31)(5.68)^2 + (7.31)(3.56)^2 --> 112.3kg-m^2
and for the sphere; 2/5mr^2 + md^2 ---> 2/5(36.55)(1.42)^2 + (36.55)(.71)^2 --> 47.9kg-m^2, correct?
Yes.
1. What is moment of inertia about an axis at the center of mass?
The moment of inertia about an axis at the center of mass is a measure of an object's resistance to rotational motion around that axis. It is calculated by summing the products of each particle's mass and the square of its distance from the axis of rotation.
2. How is moment of inertia related to an object's shape?
The moment of inertia is directly proportional to an object's shape, specifically its mass distribution. Objects with more mass concentrated towards the axis of rotation will have a smaller moment of inertia, while objects with mass spread out further from the axis will have a larger moment of inertia.
3. What are the units of moment of inertia?
The units of moment of inertia depend on the units of mass and distance used in the calculation. In the SI system, the units are kg*m^2, while in the imperial system, they are slug*ft^2.
4. How does the moment of inertia affect an object's rotational motion?
The moment of inertia plays a crucial role in determining an object's rotational motion. Objects with a larger moment of inertia will require more torque to achieve the same angular acceleration as objects with a smaller moment of inertia. This means that objects with a larger moment of inertia will have a slower rotational speed for a given amount of applied torque.
5. Can moment of inertia be negative?
No, moment of inertia cannot be negative. It is a measure of an object's resistance to rotation, and a negative value would indicate that the object is more easily rotated in the opposite direction. This is physically impossible and goes against the definition of moment of inertia.
