Moment of Inertia of a Sphere!
  • Thread starter ritwik06
I know how to take out the moment of inertia of a sphere about an axis passing through a diameter. My method is the same old one of choosing an elemental sheet and integrating. Can someone please explain to me the things I saw on Mathworld please. The method looks fascinating to me and I wish to learn it and use it for other 3 bodies.
The volume of the sphere, V=4/3 pi* r^3 , can be found in Cartesian, cylindrical, and spherical coordinates, respectively, using the integrals
http://mathworld.wolfram.com/images/equations/Sphere/Inline68.gif
The interior of the sphere of radius and mass has moment of inertia tensor
http://mathworld.wolfram.com/images/equations/Sphere/NumberedEquation7.gif
The original link is:
http://mathworld.wolfram.com/Sphere.html
regards,
Ritwik
Answers and Replies
tiny-tim
25,832
251
I know how to take out the moment of inertia of a sphere about an axis passing through a diameter. My method is the same old one of choosing an elemental sheet and integrating …
Hi ritwik! :smile:
Equations (15) and (16) are using your elemental sheet method.
Equation (17) is using the same method, but with an elemental sphere instead of a flat sheet.
Equation (18) is just a way of writing the moment of inertia for all possible diameters instead of just one … but the method of getting them is the same. :smile:
(moment of inertia of a rigid body is a 3x3 tensor, so if you write it in coordinates, it looks like a 3x3 matrix)
Could you please derive what those guys had written. I now possess an overwhelming desire to see that. Three integrals at a time seem so fascinating.
Apart from this here are one of my wildest thoughts:
What if we take the small element of sphere to be literally reduced to a point! The volume of this would be dy*dx*dz
therefore;
dM=[tex]\frac{3M}{4*pi*R^{3}}*dy*dx*dz[/tex]
Coordinates of the sphere= R cos a cos b [tex]\hat{i}[/tex] + R cos a sin b [tex]\hat{j}[/tex] + R sin a [tex]\hat{k}[/tex]
where a is the angle made by the position vector with its projection in xy plane. b is the angle made by this projection with the x axis.
Is it possible to integrate thus!!! If yes, please do tell me how.
Hi ritwik! :smile:
tiny-tim
25,832
251
Hi Ritwik! :smile:
If you use three integrals in the exam when you could simplify it to two or one, you will lose marks.
The whole point of dividing a volume into slices (what you call "elemental sheets") is to make the integration easier … you choose a slice that you already know the area of, and that saves you two integrations, and leaves you with only one.
Sorry, but that's hopeless … you have to slice the whole volume in a genuine way. :frown:
Hi Ritwik! :smile:
Oh, thats not the way here. We are given ample time in an exam- specially the Sciences and Maths. And my teacher shall appreciate it if I do the question in numerous ways.
By the way it doesnt matter. Could you please explain it to me? Please! I shall be very grateful.
Oh! That was just a thought! I already had the inkling that it might be wrong!
tiny-tim
25,832
251
ok … in (15), the sphere is divided into vertical slices of thickness dx, from x = -R to R,
then each vertical slice is divided into vertical strips of thickness dy, from y = -√(R2 - x2) to √(R2 - x2),
and each vertical strip is divided into horizontal blocks of thickness dz, from z = -√(R2 - x2 - y2) to √(R2 - x2 - y2).
Then you add the volumes of all the blocks, which is the same as the integral in (15).
(16) is very simi;ar and I expect you can work this out for yourself.
(17) divides the sphere into spherical shells of thickness dr, from r = 0 to R,
then divides each shell into vertical lunes of angular thickness dtheta, from theta = 0 to π,
then divides each lune into blocks of thicknes r sinphi, from phi = 0 to 2π
Related Threads on Moment of Inertia of a Sphere!
  • Last Post
9K
  • Last Post
  • Last Post
97K
9K
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
14K
  • Last Post
