Moment of inertia of a tire
Homework Statement:
Jane drives her sportscar East along the road at a speed of 34 mph. Each tire has an inner radius of 0.4 m, an outer radius of 0.52 m, and a mass of 6 kg.
Jane sees a sign for an elementary school, so she gradually slows down to 19 mph over a period of 5 seconds, decelerating at a constant rate.
What was the torque applied to that tire during the period of acceleration? Provide both a magnitude and direction.
Relevant Equations:
I=(1/2)(M)(radius1^2 + radius2^2)
I=(1/2)(6kg)(0.4^2 + 0.52^2) = 1.29 kg*m^2
initial:
34 mph= 15.2m/s
15.2m/s = (ω) (0.52m)
ω= 29.2 rad/s
after:
19 mph = 8.5m/s
8.5m/s = ω(0.52m)
ω= 16.3 rad/s
acceleration = (16.3 rad/s - 29.2 rad/s) / 5s= -2.58 rad/s^2
torque= |-2.58 rad/s^2 |(1.29 kg*m^2 ) = 3.3 N*m
I am confused on what the direction of the torque is.
Likes Delta2
Answers and Replies
TSny
3,017
Are you familiar with the concept of torque as a vector quantity? If so, then the answer for the direction of the torque would be the direction of the torque vector.
Your solution for the magnitude of the torque looks good, although I have not checked the numerical calculations.
Delta2
Insights Author
1,043
Torque's direction is usually perpendicular to the plane of rotation. It is not the direction of rotation (clockwise or counterclockwise) if that's what you 've been thinking.
haruspex
Insights Author
5,602
The direction of a rotation vector is a matter of convention. Standard is the right hand grip:
Curl the fingers of your right hand to mimic the rotation. The thumb points in the direction of the corresponding vector.
In the case of a slowing car from the driver's perspective, the top of the tire is moving away (forwards) more slowly, so for the acceleration your hand should be palm up. That makes the vector point to the right.
Btw, note that what you are finding here is the net torque. The brakes will apply a much greater torque, but most of it will be countered by friction from the road.
Likes Delta2
The torque points to South
Likes TSny
haruspex
Insights Author
5,602
Related Threads on Moment of inertia of a tire
  • Last Post
9K
  • Last Post
11K
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
